01-08-2003, 03:47 PM | #1 |
I'm back with 2nd truck!
Solenoid/Starter out right?
Well after coming home from work I slept for about 4 hrs and got up and got in truck to go run errands. Well the truck has no click, nothing to attempt to start. Looks like a dead starter. Tried a hammer on solenoid and nothing. I got 10 amps showing on the gauge so I know I have plenty of power. No power drains. Just came home and parked it then came out when truck was ice cold and this happens. So I'm right in thinking starter/solenoid right? I'm thinking a heat shield this time
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
01-08-2003, 03:56 PM | #2 |
B could be the ignition switch?
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
01-08-2003, 04:00 PM | #3 |
Not sure. what signs would that give? anyway to test?
01-08-2003, 04:47 PM | #4 |
I just jumped the solenoid and it started spinning. So would this be a bad solenoid? When I did it, the solenoid didn't engage to the flywheel just spun.
01-08-2003, 04:47 PM | #5 |
Nevermind
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
01-08-2003, 04:48 PM | #6 |
Yes. I jumped the starter with the key on to verify.
01-08-2003, 04:51 PM | #7 |
Don't the new starters from 88+ are mini starters? If so I might upgrade if possible then. Just got to get teh right bolt pattern
01-08-2003, 04:52 PM | #8 |
B, you might just go ahead and pull the starter and take it to get tested.
01-08-2003, 04:53 PM | #9 |
I'll do that just wanting to see about a new starter mini style and a heat shield Now if the wife would ever make it home
01-08-2003, 10:22 PM | #10 |
pkbinplano
Pull the starter and jump it with jumper cables to see if it spins.
http://www.picturetrail.com/gallery/...7496&members=1 84 chevy silverado aka The Bananna Boat |
01-09-2003, 04:40 AM | #11 |
Well it spins after taking it to get tested. Looks like either I'm wire chasing or ignition replacing. Hope just a loose wire. I'll keep you posted.
01-09-2003, 11:19 AM | #12 |
Ultimate Diesel Dude
B, there is a fusible link in the wiring down by the starter. Take a test light, and probe the wire going to the start terminal on the solenoid while someone else turns the key to start. You should have power. If not, don't forget about the neutral safety switch. Wiggle the gearshift and see what happens. Otherwise, start checking the wire going into the wire loom above the starter. The fusible link shouldn't be too far away from the starter.
Project truck: '81 C/20 converted to 6.2L TURBO DIESEL bored .040", gear drive, 6.5L injectors/pump, custom pistons, custom 4" exhaust, 700R4, 4.10's Daily Driver: '95 K1500 Tahoe, 6.5L TURBO DIESEL, NP241, 4L80E, 3.42's |
01-09-2003, 10:13 PM | #13 |
i forgot about the park nuetral saftey switch, try starting it in N?
01-10-2003, 02:42 AM | #14 |
Well it was a $.22 fix. The smaller nut came off and broke the wire. I didn't see it before when taking it off. Replaced the nuts (double nutted this time ) and fixed the wire. Starter tested out perfect. Replaced the starter back and fired right off. Now if everything was this cheap and easy to fix.
01-10-2003, 09:02 AM | #15 |
You get what you pay for
I love the cheap fixes. Trouble is, most of the time they're not any.
Glad to hear you didn't have to redesign the world to get it fixed.
Mike 1985 Chevy C-10 |
01-10-2003, 11:32 AM | #16 |
BeWarE tHe eViL CrAnkTOe!
So you got a Double nut......hee hee
~Dave~ You can call me Mike, Mike Oxlong - 1986 Chevy SWB - Stock for now - 1986 Chevy Custom SWB *Stolen 6/26/05* - 1985 Chevy SWB SOLD - 1999 T/A Some mods www.cardomain.com/id/ramairdave AIM Screenname - Jester84 |
01-10-2003, 04:53 PM | #17 |
Yeah better than the only 1 I have now and those work LOL
