Old 01-08-2003, 08:59 PM   #1
ocbaud
Garage Queen Material
rear shock mounts??
okay, sometime this month i'm gonna have my drivers side rear shock mount moved toward the center of the axle about an inch or so. i'm doing it to make room to mount the shock because the leaf spring retaining plate is in the way now.
should i go ahead and have the passanger side mount rewelded and moved so that both shocks face the same direction? what would this help?
also, my shock extenders that i have would not slip over the shock mounts, so would it be a better idea to just replace the stock shock mounts(hehe, say that 3 times fast) with the shock extenders welded in there place?
also, when i get this done, i'm also gonna have the bump stops removed, including the metal part that holds the rubber on.
ocbaud is offline   Reply With Quote
Old 01-09-2003, 02:06 AM   #2
Prerunner1982
Prerunner1982's Avatar
eric, you might be the frame checked first....
Prerunner1982 is offline   Reply With Quote
Old 01-09-2003, 03:14 AM   #3
BaggedC10
Under construction!
BaggedC10's Avatar
Hmm..........Honestly, I would not mess with the stock shock mounts. How do you plan on mounting the shock absorbers to the upper frame rail, if you relocate the lower ones? How would that work? I would notch the spring plate enough to clear the inner shock extender bolt. It helps if you place the bolt heads facing outwards (You'll just have to torque the bolts by the head---Not really a big deal). Also, I would not weld the shock extenders to the axle tube. Like I said before, it takes patience to get them on. You have to lightly pound them in place and play around with it from there. It took me about 1/2 an hour to do both. Just don't go hacking away at your truck!
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 01-09-2003, 04:36 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
If you move it you are going to affect the shock geometry/effectiveness. The shock extenders are supposed to do 2 things, 1) allow the use of a stock shock by moving the mount down 2) move the lower shock mount out to get the geometry back. Ideally, you want the shock to keep the same degree of tilt to it. Once you lower one, this angle changes. Ideally the angle should be as close to 18 degrees from vertical as possible.
Having a shock on a flatter plan makes it more progresive, and usually ride like crap.
Why are you having to move them?
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 01-09-2003, 06:49 PM   #5
BaggedC10
Under construction!
BaggedC10's Avatar
WORD. However, I disagree about shock extenders allowing you to utilize the stock length shock absorbers. Like you said, it maintains the proper geometry for optimum performance. Shock extender or not, the ride height is lowered and the valving of a stock absorber is not equal. JMO though.
He wants to relocate them because the spring plate that came with the flip kit would make contact with the shock extenders/hardware. Right, Eric?
Old 01-09-2003, 08:14 PM   #6
low 84
low 84's Avatar
just get you a grinder and notch the u bolt plate and cut the bottum heads off the bumpstop plate rivets. no need to pay someone to move the shock mounts.
as for why your extenders won't slip over the current mounts, that is weird. if they won't fit over the outside of them, will they fit on the inside? i would call sporttruckdirect and ask them, mabey you got a bum set.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 01-09-2003, 08:58 PM   #7
ocbaud
i was able to get one on, but it took about 30 minutes and it had to be bent to do it.
i guess i'm gonna try to notch the plate saturday maybe then.
its gonna suck though if i have to take the damn thing off though, because those ubolts are super long
