Old 07-31-2009, 05:44 PM   #1
Prathbun
Prathbun's Avatar
Ring Gear Id Please
Could someone please tell me what I have. There are 43 teeth on the ring gear and I would like to know what the ratio is. It looks like it's dated 2/02 and the teeth all look like new. There are shadows in the pics that are deceiving.
Thanks!!
It's Not Rust, It's Patina!!
1967 C 20 Large Window, 700R4, 283, Tilt, PS, PB.....A Rusty But Trusty Gas Hog
2008 Silverado LTZ 1500 4x4
Prathbun is offline   Reply With Quote
Old 07-31-2009, 05:47 PM   #2
Prathbun
Prathbun's Avatar
Re: Ring Gear Id Please
I would really like to just be able to take all the gears out then reinstall after powder coating but I think I need to have the shims checked and the pinion depth checked. Am I correct. I will need all new seals as well
Thanks for the input!!!
Old 07-31-2009, 08:36 PM   #3
JimKshortstep4x4
The ring gear should be stamped with the number of teeth on the pinion. Since your ring gear has 43 teeth it is probably a 43:14 or 3:07.
It is a good practice to check the backlash and contact patterns. If you are reusing the bearings and you keep the existing shims in the correct locations then the fitup should not change . This assumes that the fitup is good now and that you retorque the pinion nut to the torque value it has now.
New seals would be needed.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 07-31-2009, 11:30 PM   #4
Prathbun
Prathbun's Avatar
I thought I posted this pic. Dang. Maybe this will help with my question.
Old 08-01-2009, 04:26 AM   #5
JimKshortstep4x4
I see that it is a 14 43 or 3:07 ratio.
Jim
Old 08-01-2009, 06:28 AM   #6
68C15
blood type; Retumbo
68C15's Avatar
it is possible that during the baking portion of powder coating the housing may change dimensions. so I would have it set up fresh after it looks pretty.
68C15 is offline   Reply With Quote
