Somebody please tell me what this is called!
Hi, I'm trying to get my door lock to work and traced the problem to the wheel being loose/worn in the mechanism.
Can any one tell me what this part is actually called? Know what vehicles this part is interchangable with? Or if it can be simply dismantled and repaired or tightened? Thanks in advance ![]() Last edited by CrazyIvan; 08-01-2009 at 02:21 PM. |
Re: Somebody please tell me what this is called!
It's called a door latch assembly. Here's a link.
http://www.bobschevytrucks.com/1967-...chevy-gmc.html ![]() Dan
Dan Smith Colorado Springs, CO 71 GMC Custom Camper "Longhorn" 454, TH400 73 Chevy Camper Special (Yes, it's badged a camper special) Flat Bed Motorhome conversion 454, standard tranny "DON'T TREAD ON ME !!!" My Project: http://www.picturetrail.com/sfx/album/view/20829244 , http://www.picturetrail.com/sfx/album/view/24654442 |
Thanks,
Thats what I needed, I'll try the wreckers first see if i can save myself some cash. ![]() |
![]() Join Date: Jul 2004
Not much fixing on those, either find a good used one or replace. The star wheel is supposed to turn on the little axle in the center, but usually the wheel rusts to the little axle pin, then the whole pin and wheel starts to spin in the hole at the end and then it gets pretty sloppy.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
ah, gotcha,
Thats defo whats happened with mine. Just tried to take the door panel off but couldnt get the inside handle off. Realized that I think I need a maintenance manual, would you suggest chilton or hanes for a novice like myself? |
Asks alot of questions
![]() Join Date: Feb 2009
No need to mess with the boneyard, Ive got one, I sent you a private message
MY STABLE: '66 C10 LWB turning it into a shortbed stepside '77 LWB (my daily driver).....oh its a FORD ahhhhh! '07 MAZDA 3 (the wife's ride) |
'69 Chevy SWB
hit up a parts store and pick up the tool to remove the inner handles. there is a small wire clip on the back of the window crank and door handle. use the tool and the clip and handle will pop right off.
#8 | |
![]() Dan
#9 | |
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
The tool is like a buck and it will save you some headaches.
When you put the handle back on just put the clip on and then push handle back in place it's easier than trying to get clip on afterward.
Ivan I just took mine apart not to long ago, there are alot of rods with little c-clips that really test your patience when you put it back together.
I used a butter knife.
It looks like this.
![]() ![]() Dan
#15 |
Ah, thanks for all the advise. Will be confident taking it off now without breakin anything.
