Ex-Minitrucker
68 Tachometer Question?
I have a 292 4 spd and everywhere i look it seems that no one make a factory style tach for a 6cyl. I read somewhere that the camaro tachs work in our trucks but don't know if they make one for a 6 either. Do I have any options besides a aftermarket unit because I would really like to keep it stock looking.
its all about the +6 inches
Re: 68 Tachometer Question?
a camaro tach doesn't look anything close to stock.
I would think a 6 cylinder truck tach would be very commin compaired to a camaro 6 cylinder tach. Keep an eye on the parts board and in big truck in the junkyards. |
Ex-Minitrucker
I haven't seen any I was going to replace all the gauges in the cluster I forgot to mention I converted to HEI also so I need a stock looking 6cyl tach that works with HEI.
Ok, I have dumb question is a six cylinder tach different from a eight cylinder tach.
Ex-Minitrucker
I don't know but when you look them up in LMC and other catalogs it always says V8. And every aftermarket tach I've owned has a switch to change it from 4-6-8 or wire loops to clip.
Ex-Minitrucker
The tachs are differrent. The tach reads the electrical signal from the coil, so eight hits is two revolutions for a V8 whereas six hits is two revolutions for a 6 cylinder.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
stock tachs work just fine with HEI, just replace the plug on the end and thats it
resident oilfield trash
That being said you can calibrate a tach for a 6
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
