Old 08-02-2009, 02:45 PM   #1
Gary66
Gary66's Avatar
31.5 or 33's
can someone tell me the biggest tire that can be run on 15x10's on a STOCK height 1978 k-10? attached is a picture of the truck that my uncle had, I am building a tribute truck-also the truck that I have to do the tribute- photo attached as well- from the older picture with the aluminum rims- does it look stock height or maybe 3" lift???
2003 2500 HD Crew Cab
1965 GMC K10
1972 Chevrolet k5 blazer
Gary66 is offline   Reply With Quote
Old 08-02-2009, 03:13 PM   #2
b454rat
Re: 31.5 or 33's
Kinda look like 33s, but hard to tell. Each truck is different. I had a truck that 33s rubbed on with 8" wheels. Buddy had the same tires on 10" wheels on a truck and only rubbed a little....
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 08-02-2009, 08:51 PM   #3
Dooley
Dooley's Avatar
Re: 31.5 or 33's
I've been running 33/12.50-15's on 8" wide rims for over 30 years on GM pickup and Suburbans without any problems and no lift. I had a set of Jackman 10" wide wheels for a short while and they would hit. I got rid of them and put 8" on without further problems. Some big/wide tires don't play well with mounted running boards back of the front wheelwells also.
Dooley is offline   Reply With Quote
Old 08-02-2009, 09:18 PM   #4
Eturnit3
Bloodied Knuckles
Eturnit3's Avatar
Re: 31.5 or 33's
I would venture to say its stock height.. looking at the rims for a gauge. If you are planning to have a shop mount the new shoes, test fit em and see for yourself. i did the same at les schwab and found out that with my 72 long box, 33's would rub the fender just enough to cause some damage so i went 31's until I could lift it where i wanted it. Nice truck man!! good luck
Eturnit3 is offline   Reply With Quote
Old 08-03-2009, 08:59 PM   #5
Gary66
Gary66's Avatar
Re: 31.5 or 33's
Thanks, I am going to a shop that has both 31.5's and 33's and I am going to see if they can be mounted for a test "looK"-= do you think the top picture has a small lift?? or is it just the tires?
1965 GMC K10
