08-04-2009, 09:16 AM | #1 |
Senior Car Nut
torsion bar drop
anybody out there lower the front of their '60-'62 by backing off the adjuster nuts? not talking about a lot, maybe an inch of drop. Don't need much since I'm thinking of using 2.5" drop spindles which will allow for the easy upgrade to discs.
08-04-2009, 10:20 AM | #2 |
Re: torsion bar drop
Yea real easy . make sure your on level ground jack up the front use jack stand, and lots of PB blaster/ WD40 on the bolts.
What I did was back one side of a few turns, then do the other, untill you get the desired drop.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
08-04-2009, 11:56 AM | #3 |
yup i got 5'' of drop roughly on my 60 gmc by turning the torsion bars down.....still could of went more but......air bags on the rear no c notch......
08-04-2009, 03:46 PM | #4 |
Recreational Grease Monkey
I have about a 4-5" drop by backing off the bolts but there is a downside. The arms now hang down low and drag on everything. I tried driving it on a flatbed trailer once and had the arms hit the back edge of the trailer with an abrupt stop. =( Also unless you put some type of spacer on the bolt between the arm and frame, under hard acceleration the arms rise and fall with a hell of a noise.
Thanks, Robert 60' Chevy Stepside SWB 08' HHR SS 260hp |
08-04-2009, 07:01 PM | #5 | |
Senior Car Nut
Anybody else have the experience Revin68 describes? |
08-04-2009, 03:41 PM | #6 |
I took my down also and got a 4.5 - 5.0 drop on mine also ...I now have problems here and there with driveways ... I was gonna do the drop spindles but insted this was more cost effective and I don't have any driveability problems ..
08-04-2009, 11:14 PM | #7 |
Iyou do turn your adjustment bolts to lower your truck place a jack or a stand under your fulcrum before you turn your bolt if it breaks -----------so might your wrist ------first hand experiance
08-04-2009, 11:43 PM | #8 |
i have had NO problems with my drop, I do have drop spindles , but they are not installed yet. I will have to raise the torsion bars when I do the install
08-05-2009, 07:35 AM | #9 | |
Senior Car Nut
Now that's interesting, thanks, Slepysal. I was also wondering if t-bars work like progressive springs (more they're loaded the higher the rate, less they're loaded the softer). When you backed off the pre-load did the ride soften up? |
08-05-2009, 11:33 PM | #10 |
[QUOTE
Now that's interesting, thanks, Slepysal. I was also wondering if t-bars work like progressive springs (more they're loaded the higher the rate, less they're loaded the softer). When you backed off the pre-load did the ride soften up?[/QUOTE] you know ,the ride is not bad at all. It is a bit ruff , but it dosnt feal like a "boat" One thing to keep in mind that unlike cuttin coils, if you dont like the ride, you can re adjust them with a few turns of your wrench . here is how mine sits
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " Last edited by slepysal; 08-05-2009 at 11:34 PM. |
08-05-2009, 11:38 PM | #11 |
oh and this is what it looked like before
08-07-2009, 08:27 PM | #12 |
Senior Car Nut
So, why do people want to get rid of the t-bars. I remember them (yeah, I'm that old) they rode great. Could it be the $200 ball joints?
