08-04-2009, 12:09 PM | #1 |
64-66 CHEVY JUNKIE
Need 'OD' sizes for front hard brake lines '72'
Well what i have going on is, I replaced drums for disk on my 66 with all 72 hardware. O.K. what im looking for is what size metal lines do i need to bend them myself from the prop valve to the rubber brake lines? Do anyone have any tips or pics, THANKS Chris..........[IMG][IMG][/IMG][/IMG]
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E Do It In A Chevrolet |
08-04-2009, 12:10 PM | #2 |
64-66 CHEVY JUNKIE
Re: Need 'OD' sizes for front hard brake lines '72'
[IMG][/IMG]
08-04-2009, 12:17 PM | #3 |
Project Junkie! Fishing Poor!!
I believe the brake line diameter is 5/16" for front and 1/4" for rear. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
08-04-2009, 12:24 PM | #4 |
64-66 CHEVY JUNKIE
Thanks for your help Classic Heartbeat............ Chris...
08-04-2009, 12:26 PM | #5 |
Your welcome. WES
08-04-2009, 12:26 PM | #6 |
20' Daredevil (Ret)
My '72 OEM hard lines are 1/4" and 3/16".
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
08-04-2009, 12:30 PM | #7 | |
Resident Curmudgeon
I believe Wes meant 3/16th not 5/16th. The rears are 1/4 and the fronts are smaller
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
08-04-2009, 12:31 PM | #8 |
I just installed new SS lines on my 72. The hoses are different on each side up front. They change from the splitter that is located right below the master cylinder. The hard line that goes to the driver's side is a 7/16" nut and the passenger side is a 3/8" nut. Sounds crazy but when I ordered the rubber lines and they were both different, I questioned the supplier. Sure enough, when my brake lines came, they were both different. If you need some pics, let me know and I will take some for you.
08-04-2009, 12:31 PM | #9 |
64-66 CHEVY JUNKIE
Well if it helps the 72 brakes are 1/2 ton set-up...
08-04-2009, 12:37 PM | #10 |
64-66 CHEVY JUNKIE
YES PICS!! I have installed the lines from the master to the prop val. from the pro val to rubber lines is were im stuck at, Chris...
08-04-2009, 12:38 PM | #11 |
64-66 CHEVY JUNKIE
[IMG][/IMG]
08-04-2009, 12:41 PM | #12 |
I have read too many post this morning..lol CPNE is correct 3/16" front..lol WES
08-04-2009, 01:04 PM | #13 |
It looks like to me you have both the passenger and the driver's side line coming out of the proportioning valve. There are two lines that come out of the proportioning valve, one is for the rear and one is for the front. The front runs down and goes into a brass splitting block (I got mine at NAPA). From the splitting block, the driver's side goes up and over the front cross member and then turns out towards the wheel to the bracket where the rubber hose mounts into. The passenger side runs along the bottom of the front cross member with the rear line. Once it gets past the motor, it turns up and over the top of the front cross member and into the bracket where the rubber hose mounts. Hopefully the attached pictures show what I am trying to describe. You might also do a search....I found some great pics when installing mine from one of the members on the board. Good luck!
Joel |
