08-04-2009, 02:25 PM | #1 |
Dual elec fans
Does anyboby make a dual electric fan setup for a 72 pickup?
08-04-2009, 02:35 PM | #2 |
BOHICA
Re: Dual elec fans
I don't know of one specifically, but check the vendor area, one of those links should lead you in the right direction.
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig! |
08-04-2009, 02:43 PM | #3 |
Re: Dual elec fans
May be more than you're looking for but this is a combo.
http://www.jegs.com/i/Be+Cool+Radiat...82058/10002/-1 And if you wanted to use a generic fan, check out GMCPaul. He's got a fabricated dual fan shroud. Last edited by Ole Blue 68; 08-04-2009 at 02:45 PM. |
08-04-2009, 02:52 PM | #4 |
The Few, The Proud
Re: Dual elec fans
Try GMC Pauls or Wes at Classic Heartbeat. Both are board vendors and have great customer service. I just installed dual electric fans on my 69 K10 using parts from both vendors mentioned above.
Shannon |
08-04-2009, 02:41 PM | #5 |
Re: Dual elec fans
Yes, CPP sells one as well as most of the 67-72 truck vendors like Car Shop Truck Shop in Orange CA. Very expensive though but has a nice shroud, which is best to have. I have an electric fan in my Camaro with a 396 and it has been a chore to get it to cool well. Had to build a custom sheet metal shroud. The mechanical fans do a better job of cooling a hard to cool engine, IMO.
08-04-2009, 03:04 PM | #6 |
Re: Dual elec fans
Beautiful setup on that K10. It sure is nice to see evrything new and shiny like that. Wish I had the time, space and money to do that to my truck.
08-04-2009, 08:43 PM | #7 | |
The Few, The Proud
Re: Dual elec fans
Thanks for the compliment.
Shannon |
08-05-2009, 02:48 AM | #8 |
Re: Dual elec fans
You could also look at Flex-a-lite and Old Air Products.
08-05-2009, 12:23 PM | #9 |
Re: Dual elec fans
I have the older model straight blade Flex-A-Lite Black Magic fan and the fan motor crapped out in short order. However, they sent me a new upgraded/redesigned motor for free. Runs great now and cools well. Good customer service.
08-05-2009, 12:57 PM | #10 |
Re: Dual elec fans
I have to agree with mclairmo; What's wrong with a good old mechanical fan? The less electrical crap you have to contend with, the better. Plus, as long as everything is in good working order, these trucks typically do not overheat, even with a fairly built engine.
If yours is overheating with a mechanical fan, start checking things until you find out why. I was running about 25° of advance at an idle on a built 350 and could run at 160° all day long. |
08-05-2009, 03:05 PM | #11 | |
Re: Dual elec fans
I'm running the ones from GMC Paul's and love them. In the desert you need all the help at idle, plus better performance. with the a/c my truck never gets hot.
1972 c-20, 350/350, dana 60 w/456 gears(no Posi) |
08-05-2009, 03:26 PM | #12 |
Re: Dual elec fans
The dual electric fan and shroud setup from WES is an awesome quality piece. Plus it comes from one heckuva nice guy.
08-05-2009, 03:35 PM | #13 |
Re: Dual elec fans
I'll leave the debate alone after this, but I live in the desert... It's called Los Angeles... I've run it in bumper to bumper traffic in 110° weather, as well as running 70 MPH uphill in the same weather, and my temp just sits there. Not sure how much rougher it gets than that. The only thing that gets overheated is ME!
Anyway, as I said, I'll leave it alone. Good luck with the fans. Last edited by 69GMCLonghorn; 08-05-2009 at 03:36 PM. |
08-05-2009, 03:36 PM | #14 |
Re: Dual elec fans
Another issue nobody has mentioned is the amp draw these two large fans will have. I had to upgrade to a 105 amp alternator to make sure that my big electric fan does not blow out my alternator. Also, I used to have it wired up so that even with the engine off, the fan would stay on until the radiator went below 180 degrees in order to prevent heat soak. The fan would stay on for 5-10 minutes after I turned off the engine and would sometimes drain my battery just enough so it would not start, especially in the heat. I now have it wired to shut off with the ignition, which has solved that problem.
08-05-2009, 03:44 PM | #15 |
motor exploder
Re: Dual elec fans
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
08-05-2009, 04:23 PM | #16 |
Project Junkie! Fishing Poor!!
Re: Dual elec fans
We have had our system on our BB 4X4 Blazer for over 10 years now without any issues what so ever. Our temps don't get over 100 here much, except maybe this year..lol 108 at our shop last weak.. We have sold systems to people in Southern Texas, Arizona, Southern California, and many other places. I know that we have at least 80 of these out on trucks to date and have had no problems. Mudder cut a couple of holes in one of our shrouds to let more air flow through while the truck was running down the road, but that was it. He used his own fans also. Anyway most all new vehicles run electric fans now too, so I wouldn't be afraid to use them anywhere. The added benifites are no loss of power due to the engine always having to turn the fan and quicker rpms. I put them on everything I build. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
08-05-2009, 04:37 PM | #17 | |
Re: Dual elec fans
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys Last edited by Classic Heartbeat; 08-05-2009 at 04:38 PM. |
08-05-2009, 05:01 PM | #18 | |
Re: Dual elec fans
08-05-2009, 04:48 PM | #19 |
Re: Dual elec fans
WES,
What is the amp draw on your fans and will a regular alternator with 60 or 65 amps handle all that? |
08-05-2009, 04:55 PM | #20 |
Re: Dual elec fans
I don't have a fan in front of me to read the amp draw, but I can tell you my BB Blazer has a 45 amp alternator. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys Last edited by Classic Heartbeat; 08-05-2009 at 04:56 PM. |
08-05-2009, 09:17 PM | #21 |
Re: Dual elec fans
i have a dual fan setup on my truck.. i can take pictures if you like... never bothers my battery
72 c-10 lwb: mild 350 , turbo 350 w shift kit, 3.73, drop spindles and rear drop springs, e-fan, relocated fuel tank, roll pan, Progressive wheels, 02 silverado buckets&console |
