08-05-2009, 12:05 AM | #1 |
Grease Monkey
BBC Cross member Problem
I hit a roadblock... The DIY4x cross member lowered the motor down quite a bit, causing the the headers to have serious clearance issues. I moved the engine forward 3 1/4" so the frame is narrower, but the tall valve covers clear the firewall. The exhaust ports on the heads are about an inch or two above the frame instead of 3-4". Any suggestions?
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
08-05-2009, 01:48 AM | #2 |
Re: BBC Cross member Problem
call kert and tell him what is going on. his is a great guy to deal with
nickle and dime |
08-05-2009, 09:50 AM | #3 |
Ya yer way lower than I am, mine is in the stock location so..and I'm not sure if our frames are different?? Well that and I'm not using the DYI x-member...so basically my post doesn't help you in anyway other than confirming what you all ready know... I need more
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
08-05-2009, 08:27 PM | #4 |
6>8 Plugless........
I put a 396 in my old 70 K20 and I had to move the engine ahead and cut my firewall to run the tall style valve covers like i wanted to. I wonder if they built those engine mounts with that thought in mind?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
01-31-2010, 04:07 PM | #5 |
Grease Monkey
Its in and everything fits without any major mods. Heres the link to my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=331347
