Old 05-19-2002, 05:26 PM   #1
jmanz69
Careful, they attack...
jmanz69's Avatar
Post Diff between 67-71 and 72 BB motor mounts
What is the difference between them. Would they both work with a 69 auto cab? I am thinking of going to a BB, and have noticed I can get my hands on 67-71 mounts much easier than 72 mounts.
Comments anyone?
69 swb - in the process of being torn down and born again!
jmanz69 is offline   Reply With Quote
Old 05-19-2002, 09:05 PM   #2
jmanz69
jmanz69's Avatar
Post
ttt
Old 05-19-2002, 09:14 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
I discovered I have both. If I get a photo host going here I can post pics.
The 68 - 71 are much taller, and put the engine higher, while the 72 is lower.
Turns out both my 350 powered rigs have them.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
E-mail longhornmail@yahoo.com
My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough?
Columbus Ohio
Old 05-19-2002, 09:17 PM   #4
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
Post
I too have searched the world for the elusive photo of a pair of 72 Big Block mounts. The 67-71's will work. They look similar to the small blocks but beefier and I believe a different height. (Shameless plug!!) Mine are on ebay http://cgi.ebay.com/ebaymotors/ws/eB...dexURL=0&rd=1. $10 off for board members if you buy it now. Email me to let me know before you "buy it now".
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 05-19-2002, 09:18 PM   #5
jmanz69
jmanz69's Avatar
Post
Longhorn,
I can post them for you. send me the pics.
Old 05-19-2002, 09:31 PM   #6
Longhorn Man
Post
You have mail
Columbus Ohio
Old 05-19-2002, 09:32 PM   #7
Desert Rat
Desert Rat's Avatar
Post
I have several sets of the 68-71 Style in appearance they are similar to the SBC ones,the 72 are very similar to the 73 up pickup style,i can try to get a pic but it wont be today.I have a set of 68-71's for $60
Desert Rat is offline   Reply With Quote
Old 05-19-2002, 09:47 PM   #8
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Thumbs up
I understand the rubber mount part for the 67-71 are big $$$$$$90 and the 72 are are like $15. Can someone confirm this?
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 05-19-2002, 10:09 PM   #9
Chevyman69
Vortec 350's Suck
Post
68-71 towers are relatively inexpensive but the rubber is expensive( bought mine from GM). 72 the towers are the big money but the rubber mounts are discount auto store items, so you get it either way.
69 CST 10, 402, steel crank, heavy rods, Federal Mogul Forged Pistons, 9.9:1 compression, polished ported 781 heads 2.19/1.88 manley stainless valves, Crane Powermax Hydraulic roller 288/296 and .587,.610 lift, hardened pushrods, Crane Roller Rockers, Weiand Action Plus, 750CFM Rochester QJET, MSD HEI, MSD 8MM Wires, Dynomax Ceramic coated headers, should be about 500 H.P. 700R4 2500 stall, pretty nasty shift kit, 373 Auburn Pro Series Posi, buckets/console air/tilt/tach 4wheel discs
Daily Driver: 92 Chev Reg Cab LWB Silverado 4x4, loaded, 350 Accel filter/cap/rotor/coil/AC Delco wires/AC Delco RapidFire plugs, Edelbrock intake and headers, 180 degree thermostat, Hypertech Thermomaster Chip, true duals 700R4 with B@M Shift Kit for now!
69 Chev CST 10 reg cab lwb
Daily Driver: 92 Chev Reg Cab LWB Silverado 4x4, K.I.A 7:51 AM 04/22/03
Will be resurrected
Chevyman69 is offline   Reply With Quote
Old 05-20-2002, 06:49 AM   #10
trukman1
Post
So what makes the '72 BB towers so much more expensive? I would think there would be more '72 BB trucks out there, hence, more of the mounts available making them cheaper. Anyone care to explain? Thanks, Gary
1967 K30 461/TH400/Np205/D60/14FF/BDS
MTZ 375/75/16 on 16x10 Pro Comps
trukman1 is offline   Reply With Quote
Old 05-20-2002, 11:46 AM   #11
Longhorn Man
Post
Why would there be more one year mounts then 4 year mounts?
Like the 67 GMC grill, the 72 big block mounts may never be reproduced, so the older ones will be the more common ones. (like the case is anyways)
Columbus Ohio
