Old 08-05-2009, 04:02 PM   #1
sams60gmc
sams60gmc's Avatar
quick x member question.
So I've read a bunch about doing the swap but I'm halfway thru and I just wanted to double check whats going on. I have my new cross member up in the frame rails and the upper rear bolt hole lines up. Is that the one that I need to have it bolted up to or do I need to slide it forward? Also I read that that hole needs to be sloted out. But I'm not sure why because a bolt just goes thru it. Thanks for the help.
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline   Reply With Quote
Old 08-05-2009, 04:39 PM   #2
bubba327
HOW long until spring??
bubba327's Avatar
Re: quick x member question.
On my 64 when I put a 71 cross member in, The holes I needed to move were the two lower holes on the sides which have the bolts from the inside of the frame . All the bolts with nuts lined up. Those two only needed about 1/4 to the rear and 1/4 up. I just used a die grinder. I also used new grade 8 bolts.... just because the originals were 45 years old
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 08-05-2009, 05:13 PM   #3
sams60gmc
sams60gmc's Avatar
So I completely blew it and forgot to measure anything before I pulled it all apart. Does anyone have any measurents from the cab mount to the cross member or any other measurents to make sure I get my crossmember in the right spot.
Old 08-05-2009, 07:49 PM   #4
Oklahoma
On my 62 the frame has holes notched out where the upper a-arm studs stick thru. I measured it but dident need to becaues of those holes. At least I hope I dident have to bother with the measurements.
Oklahoma is offline   Reply With Quote
Old 08-05-2009, 07:55 PM   #5
Oklahoma
here are a few pics
Old 08-05-2009, 09:43 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
This photo shows where the new holes went on my swap. The upper right is the one that was slotted upward to allow the frame to sit flush on the crossmember.
