removing body side molding clips
what is the easiest way to get these clips off the side? im trying to get all the clips off and get everything ready to get the sheet metal straight
Loving the Jimmster
Re: removing body side molding clips
great question my son is doing the same thing with his
Under Construction
The clips have a nut on the back of them, similar to the nut on a emblem.
you could remove the nut and the clip will then fall off, I guess you could also grind the surface of the clip to remove it and push the remainder through the hole.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 08-06-2009 at 09:30 AM. |
either way works fine, I'd try to save them as you'll need them later.. that is if you dont buy new trim kits
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... ![]() 71 ![]() |
Moderator
![]() Join Date: May 2007
You need to take off your inner fenders to access the nuts to remove the clips on the front fenders. You need to remove the inside door panels to access the nuts on those.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
I ground mine off. The bolts were rusted on the inside. I dont plan on putting the trim back.
I didn't have to take the door panel off on mine. They had a screw in the front, a nut in the back and stick on's in the middle.
SWB 4x4 Collector
![]() Join Date: Jun 2001
vegas, if you are going to just toss them and don't destroy them taking them off, I would be interested in them. Can't ever have enough little parts as spares. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
