Old 08-06-2009, 06:07 PM   #1
Chevyman680063
Chevyman680063's Avatar
How tight should trans pan bolts be?
Well I had to get another pan for my transmission since the old one seems to be warped and was wondering how tight the bolts need to be. I've heard they should be a little tighter than hand tight, that they should be torqued to a certain spec., and that they shouldn't be torqued b/c that would be too tight. So which is correct? Also, is there anything I can put on the pan to help hold the gasket in place while I'm installing the pan? It's a TH350 if that matters. Thanks in advance for the help.
Chevyman680063 is offline   Reply With Quote
Old 08-06-2009, 06:15 PM   #2
brak
brak's Avatar
Re: How tight should trans pan bolts be?
this is really a question for the Engine/Drivetrain forum, and i'm positive the answer is there, but here's what i've got...
It's been a while, and i don't have my manual handy, but IIRC the torque spec is in Inch Lbs, so that should tell you not very tight.
too tight will warp the pan/gasket, and cause leaking issues.
<--EDIT-->
here's a thread that may be helpful
http://67-72chevytrucks.com/vboard/s...79#post2035079
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 08-06-2009, 06:22 PM   #3
Chevyman680063
I think that's what was done to the old pan since it's warped and leaking all my trans fluid out. Why must people over tighten, WHYYYYYYYYYYY?!?!
Old 08-06-2009, 06:38 PM   #4
72 cheyenne pdx
72 cheyenne pdx's Avatar
My grandfather told me when tightening the valve covers, Trans pan and the oil pan to hand tighten them and then with a wrench, give them a quarter turn. I am unsure what that turns out to be with a torque wrench, but it has always been good for me.
72 cheyenne pdx is offline   Reply With Quote
Old 08-06-2009, 06:43 PM   #5
mclairmo
I agree with above torqueing technique and I also spray the transmission pan contact surface on the tranny case, pan rail on the pan and gasket with that red high tack spray from Permatex and it always seals everything up. Have to clean all the surfaces with wax/grease remover first and read the directions on the can of high tack. Most parts stores carry high tack. I also switched to a cast aluminum trans pan and rubber seal to help seal better. The stamped steel pan and cork gasket combo sucks.
mclairmo is offline   Reply With Quote
Old 08-06-2009, 07:03 PM   #6
cdowns
cdowns's Avatar
10-12ftlbs
Old 08-06-2009, 07:28 PM   #7
mclairmo
That's about hand tight with a standard box wrench.
Old 08-06-2009, 07:30 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I just built a TH350 today coincidentally. The specified torque figure is 13 ft/lbs.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 08-06-2009, 07:41 PM   #9
brak
brak's Avatar
Well that settles it. i don't recall correctly
Old 08-06-2009, 07:54 PM   #10
Lugnut64052
Middle-aged Curmudgeon
Lugnut64052's Avatar
The flange metal will get pulled up around the holes from overtightening, causing leaks. Look at your old pan-- if the metal is sort of coned up around each hole that's what has happened.
It's easy to fix. Take the peen end (the rounded end) of a ball peen hammer, hold the flange over some thing flat (I use the corner of a vise jaw) and peen the metal back down flat around the holes. It should seal back up fine-- 10 to 12 foot-pounds, like cdowns said. A 1/4" ratchet, hand tight, is about right.
Bret
Check out the site's Truck Tech FAQ.
Be a site supporter.
My more-or-less pathetic build thread.
Board members I've met:
Longhorn Man
Dieselwrencher
jholley
big mike71
Lugnut64052 is offline   Reply With Quote
Old 08-07-2009, 02:38 PM   #11
mclairmo
I tried this on my old steel pan and it still leaked. That's when I swtiched to aluminum. They are cheap and seal better with the thicker rail.
Old 08-06-2009, 07:55 PM   #12
68C10withA396
68C10withA396's Avatar
I replaced my gasket on the TH350 3 days ago and in order to keep the gasket lined up i just shoved the 4 corner bolts through the pan and then gasket holes and the bolts were held in by the gasket and in turn they kept it lined up perfectly. I hand tightened all bolts in a criss/cross pattern and torqued them to 13 ft lbs.
"Some people spend an entire life time wondering if they ever made a difference... The Marines don't have that problem."
President Ronald Reagan
'68 C10 SWB 396/350/4.11
68C10withA396 is offline   Reply With Quote
Old 08-07-2009, 06:37 PM   #13
tim21391
tim21391's Avatar
i usually hand tighten them.. then slap a close end wrench on it and grab it right at the head and snugger down.. no leaks yet... knock on wood
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 07-17-2012, 02:02 AM   #14
CEE1NG_RED
My '68 manual says 8#s, but the lowest my torque wrench goes to is 10#s. It ranges from 8#s to 13#s so I'm not so sure. I have a Moroso blue gasket and did 10#s. I'll find out if it leaks once I fill it up with trans. oil sometime this week.
- 1967 Chevrolet C/10 SWB fleetside (New Project).
- 1969 Chevrolet C/10 SWB fleetside (SOLD)
- 2000 Ford Mustang 232 (DD)
- 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver)
CEE1NG_RED is offline   Reply With Quote
