08-09-2009, 06:11 PM | #1 |
Helper bags
1985 c10 silverado. Looking for some info on a good helper bag system 1000 lbs would be plenty. Truck is c-notch and flip kit with blocks 4in drop rear.
Thanks for the help |
08-09-2009, 07:35 PM | #2 |
Re: Helper bags
Chop off those u-bolts.... that's an issue waiting to happen!
Did you weld those c-notches in yourself? If so, you prob have the skill to build a AOL set-up. If not, ART makes a simple bolt-on kit that works well. Before considering either, you'll need to gusset & strengthen your 'breaches' as it sits. I would not trust the bottom of that frame-rail to support heavy loads even w/the ends of the notch plate welded. I used the same Western Chassis c-notch plates. For my home-made AOL set-up, my plates were first bolted in using the supplied GRADE-8 1/2" fasteners. When I cut the OE framerail for the 'C', I made sure the gap between the frame & the c-notch plate was just right & welded the seam (fore & aft). I then welded the c-notch plates on all edges & along the inside of frame along the c-notch arch as much as possible. Build for worst case scenario when you plan to load the vehicle & are out on the same roads as everyone else. There is no compromise when it comes to the safety of others.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-09-2009 at 07:48 PM. |
08-09-2009, 07:42 PM | #3 |
Re: Helper bags
Thanks, but i did all the work 10 years ago and no problem yet.
08-09-2009, 07:54 PM | #4 |
Re: Helper bags
That's the key word in your statement. Why not trim the extra length off of the u-bolts? It doesn't impact the strength of what you have & would be safer than it is currently.
08-09-2009, 07:59 PM | #5 | |
Seņor Member
Re: Helper bags
08-09-2009, 08:05 PM | #6 |
Re: Helper bags
Yes you guys are all right and i should cut them down and will when i put the new bags on.
When i did it all those years ago wasent to worried and i still havent had a problem yet, but it is time to move forward and start putting some love back in my ride. Thanks guys |
08-09-2009, 08:31 PM | #7 | |
Re: Helper bags
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-09-2009 at 08:32 PM. |
