08-10-2009, 11:34 AM | #1 |
what trans cross bar for 700r4??
heys guys, just picked up a 700r4 for my 65 c20, curious if there is a different cross bar i have to use, or the stock will work, or if just some fabrication is needed, any input would be great!
1971/67 c10 short bed-cleaning up now-sold 1970 chevelle-put on hold to play with new truck 1968 nova-tube chassis drag car 2006 1500hd-gets me to work 2005 honda pilot-wifes baby hauler |
08-10-2009, 11:59 AM | #2 |
Registerd User
Re: what trans cross bar for 700r4??
If it's for an auto trans in a 64-66 it will work. I just had to move mine back to the rear set of holes.
08-10-2009, 12:01 PM | #3 |
kingp411,
Check out this link ...It tells you what was used and possible other mods needed ... Good Luck !!! http://www.persh.org/Pickup/IdeaPage.htm Last edited by 62 Longbed; 08-10-2009 at 12:02 PM. |
08-10-2009, 11:50 PM | #4 |
60-66 Nut
You can use the auto trans crossmember from most any '67-'87 2wd truck, Suburban or Blazer. You'll just have to drill some holes in your frame to bolt it down. You will also need to get the correct trans mount to fit the crossmember. Most 700R4 trans mounts have a single stud in the center. A lot of the truck trans crossmembers will have 2 holes for the trans mount. The older 2 bolt style mount will bolt right up to the 700R4. This is a better style mount IMHO.
