Old 08-12-2009, 07:36 PM   #1
stevewhitmore
stevewhitmore's Avatar
Question Help-Lost my anti freeze installing headers
While installing my new headers, I had to remove the coolant sensor in the side of the block and lost most of my antifreeze in the process.
Question is, can I start the motor without this antifreeze without doing harm to the motor? Probrably a pretty dumb question, but not my first to ask you guys who have been great help in the past and I don't want to blow a motor
By the way, I used the Summit headers on my 69 as you suggested and they went on flawlessly.
Thanks for any guidance
stevewhitmore is offline   Reply With Quote
Old 08-12-2009, 07:45 PM   #2
fixit-p
fixit-p's Avatar
Re: Help-Lost my anti freeze installing headers
You only lost the anti freeze that was above the plug I'm assuming on the head is so you still have coolant in the block top off the rad, start it up when the thermostat opens top off the rad again and you should be good.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 08-12-2009, 07:46 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
Edit: fixit-p's got you covered.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 08-12-2009, 07:52 PM   #4
stevewhitmore
The radiator is full, I am just worried about the motor not having anything in it until the thermostat opens up, will it be ok starting it like that? Then I can refill the radiator
The sensor did go into the head above the plugs
Old 08-12-2009, 08:00 PM   #5
Skirkpat
Skirkpat's Avatar
The engine will be fine. Just fill it up after you start it.
1969 Short Stepside
1969 4 WD Suburban
1970 1 Ton Dually....Misfit
oh, and a 2001 HD 2500, 8.1 Allison Shortbed 4 Door
Skirkpat is offline   Reply With Quote
Old 08-12-2009, 08:04 PM   #6
68shortstep
Looks good at 20-ft .....
68shortstep's Avatar
Don't know how cold it gets there in the winter, but I'd be sure & check the antifreeze for "how low can you go?" sometime this autumn before the snow flies...............
More than one motor ruined by people filling up with water in the summer & forgetting that.
68shortstep is offline   Reply With Quote
Old 08-12-2009, 08:07 PM   #7
stevewhitmore
Thanks everyone, now I gotta go start this thing up with peace of mind and see how she sounds
