Old 08-13-2009, 12:18 PM   #1
redbaron69
redbaron69's Avatar
3 speed to auto driveshaft ?
hey guys hope everybody doing good. my question is, my truck is a 3 speed now and puting in a auto. i got a 2 piece drive shaft what changes am i gonna have to make to the driveshaft to make it work thanks
69 short fleet 350/350 "under construction"
70 short step 307/3 speed
redbaron69 is offline   Reply With Quote
Old 08-13-2009, 01:04 PM   #2
BarryB
BarryB's Avatar
Re: 3 speed to auto driveshaft ?
Does it have the three spd saginaw transmission??And your swapping in which automatic? If 3spd to a th350 If so, you should be able to just pull your manual trans, and swap the autoin it's place. The driveshaft should be the same. you'll need an automatic crossmember for trans.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 08-13-2009, 04:33 PM   #3
redbaron69
redbaron69's Avatar
not sure if it a saginaw or not? how can i tell? just your standard 3 on the tree. and yes it will be a th350
Old 08-13-2009, 05:47 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
There are three different lengths of TH350 trans too, so you can't just generalize what will fit. You need to measure your current trans versus the new TH350.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
