08-16-2009, 07:25 PM | #1 |
manual to power steering!
i have a 71 c10 with a v8.. and i would like to know what parts i need to do this swap?
08-16-2009, 07:51 PM | #2 |
sharp as a marble
Re: manual to power steering!
reman steering box should be readily available from the local parts store
reman power steering pump // same as above mounting brackets this site, or vendors selling truck parts power steering hoses same as above pulleys site vendors fluid a few hours work, and then you can steer your truck with 2 fingers !! |
08-16-2009, 08:48 PM | #3 |
67-72 parts collector,…
I agree.
Look in the parts section. Board members, like Teeitup, usually have trucks that they "part out" on a regular basis. They should be able to hook you up with everything you need.
08-16-2009, 09:01 PM | #4 |
hardest part is finding pulley's that all line up. Nice if you can pull it from a donaor truck, get all brackets and pulley's together.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
08-17-2009, 11:10 PM | #5 |
Like msgross said, the biggest pain is all the pulleys for the accessories - if you have singles on the balancer and waterpump the easiest is to get everything off the same engine for your change or you will have a never ending search for the pulleys that all line up. When I changed mine I used a PS box off a 79 truck - had a quicker steering ratio that was quite noticable from the stock 68 box. I think the 78 and newer have the quicker ratio, if you use one from a 1980 or newer that is when you find more metric used - the hoses are different also o-ring style - the stock application hoses for my 68 fit the 79 box on mine along with the rag joint and pitman arm. I got my box from pick a part in Phx for $20 and needed a $7 seal kit from NAPA.
09-07-2009, 09:21 PM | #6 |
I've been wondering about this as well. I have a 93 burb that I am going to be pulling the engine and all kinds of stuff off of and was wondering if I could use the steering box and pump from the 93 to go onto my 72, Along with the brake booster master cylinder setup.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod. |
09-08-2009, 09:31 AM | #7 |
Happy to be here
If it were a 91 you would be in luck. That's the same set up as 73-87 trucks. Unfortunately in 92 everything changed to the new platform. I don't think any of it will be a "direct" swap.
09-08-2009, 09:21 AM | #8 |
I want to go the other way,from power to manual,where in Canada are you?
09-08-2009, 08:44 PM | #9 |
Is that when they changed the burbs and blazers fromthe squared front ends to the slightly sloped/ rounded look?
09-08-2009, 09:12 PM | #10 |
Watch out for your cornhole !
Yes, 92 was the first year for the new body style on the Subs and Blazers.
09-08-2009, 10:46 PM | #11 |
optomistic ah-so
You should add a pitman arm and rag joint for power steering setups to the list of parts you'll need--splines are different in most cases. Both are available through regular maintenance sources.
I've been planning to do this myself "down the road sometime," and looking for alternatives to buying a reman or resto box--but everything else I run into used later is for bolting to the inside of the frame rail or something else that involves serious downtime. I'm trying to learn more about T-bird racks before I get that far, though.
Rubbing is Racin' Ribbing is Bench Racin' 1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305. Last edited by CSGAS; 09-08-2009 at 10:48 PM. |
