Old 08-17-2009, 04:30 PM   #1
454inthehood
454inthehood's Avatar
Need some input on control arms. .
So heres how the story goes. .
I got myself a 67, stock floor body drop, full frame from the front clip back with one hell of a Z. all i need to finish up the front is a set of control arms. Im Leaning towards ART but ive heard the bushings tend to wear and crack kinda quick so ive been researching some other options but im still not sure what application to go with. Im going with at least a 22inch wheel with 3 inch drop spindles so stock arms are out of the question. Lemme know what you guys think or if you have any other suggestions. Thanks in advance!!
67 c10 Stockfloor Bodydrop
454inthehood is offline   Reply With Quote
Old 08-17-2009, 05:01 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Need some input on control arms. .
You have a couple choices and both companies have members here.
Contact Nathan Porter (member Porterbuilt) of Porterbuilt Street Rods. www.dropmember.com.
Look here at just some of his products:
http://67-72chevytrucks.com/vboard/s...d.php?t=351264.
Another member is Thorbecke Bros of www.*****************.
Check out Jason's products here:
http://67-72chevytrucks.com/vboard/s...ight=Thorbecke.
Keith
Convert to disc brakes.
Old 08-17-2009, 07:01 PM   #3
SCOTI
SCOTI's Avatar
I'm curious where you heard the "bushings tend to wear and crack kinda quick"? ART arms use OE rubber bushings or aftermarket poly bushings. The rubber bushings in my 74 were in service for 28yrs before getting replaced....
Porterbuilt arms would be my first choice, ART second, & SD third.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-17-2009, 08:52 PM   #4
2wd73blazer
I am curious why SD is the third choice. I bought some and after seeing a set. I thought they were very well built and they were a good bit cheaper than ART. I am new to these types of suspension parts so any info would be appreciated.
2wd73blazer is offline   Reply With Quote
Old 08-17-2009, 09:42 PM   #5
SCOTI
SCOTI's Avatar
I believe they're the heaviest.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-17-2009, 09:53 PM   #6
PBFAB.COM
PBFAB.COM's Avatar
We've used the ART arms for several years with good success, and never had any issues with the bushings wearing excessively. We have since began building our own arms. The main difference between our arms and the others, are the machined Delrin bushings we use. I decided to use delrin for a few reasons: less deflection than rubber impregnated or polyurethane bushings; self-lubricating (don't get the squeak noise); simple and easy installation (no press required to assemble or disassemble).
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 08-17-2009, 11:11 PM   #7
454inthehood
awsome thanks for the input guys, im leaning towards porterbuilt now forsure, they only come in raw finish correct? and bolt directly to a stock crossmember if im not mistaken?
Old 08-17-2009, 08:52 PM   #8
XXL
Señor Member
XXL's Avatar
I've had a set on my truck that were from ART's first production run. I am unaware of any cracks, and I don't believe the bushings are worn.
XXL is offline   Reply With Quote
Old 08-18-2009, 12:30 AM   #9
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Not having to use a press to change bushings would be awesome. Those things are really in there!
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 08-18-2009, 06:11 PM   #10
lolife99
lolife99's Avatar
454inthe hood,... go Porterbuilt,... you won't regret it.
Keith
Old 08-19-2009, 11:38 AM   #11
454inthehood
thanks lolife, yea thats what ive decided on quality seems second to none
Old 08-19-2009, 06:09 PM   #12
lowdownstar
big guy
lowdownstar's Avatar
i can't say how the others are but i can tell you about Nathan at porter built He has been great to work with, and is always willing to help! I have a set of his arms and i really like them so far.
good luck your your project
Ray
lowdownstar is offline   Reply With Quote
