Chance
![]() Join Date: Sep 2001
Why does my new windshield leak?
I purchased a new windshield, weather stripping, and windshield trim. After getting it installed it leaks in a few places. Before it was the original glass and weather stripping without the trim. Is there a trick to getting the glass installed properly? Is there higher quality weather stripping out there? Or do I need to not use the trim? Please let me know what you guys think because every time it rains I get water all over my new interior.
1968 Chevrolet Stepside BB 396 w/TH400 1972 Chevrolet 3/4 Ton 4x4 BB 496 w/TH400 |
Re: Why does my new windshield leak?
Your local glass shop should be able to seal it for you. They use compressed air at the shop near me to find where the water is coming in and then use a special sealant gun to seal the leak.
The top outer edges of the seal is where I have seen most leaks on these windshields. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
i'm not understanding what you did// there are 2different gaskets one for trimone without trim// i've never seen the trim cause a leak/
/did you clean the windshield channel real good before install?did you use plenty of lube on the gasket during install to aid in seating the gasket? where exactly is the leak? have you tried reseating the gasket at suspected leak areas?
i had a new windshield put in my 72 and it also leaked so i brought it back in and they put a sealant around the whole windshield
1970 c/10 swb (show truck) 1972 custom/10 deluxe 4x4 (restoration pending) 2011 silverado ecsb z71 (daily driver) |
Chance
I have the the weatherstrip with the groove for the trim. I cleaned the glass and rubber before it was installed. After it was installed it seemed like the rubber was too small for the glass since the rubber didn't look like it covered equal amounts on the driver side. It leaks from the bottom on the driver and passenger sides. Are there better quality weatherstripping out there? It's really frustrating.
The water will usually enter at the top outer edges and then it exits at the bottom. Trim or no trim usually does not make a difference. The Service Manual does suggest sealing the top outside corners.
I am not sure who has the best seals. I got the last one from GMC Pauls and it worked well. Jim
Moderator
![]() Join Date: May 2007
I have heard that Precision makes the best windshield gaskets.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 08-19-2009 at 08:05 PM. |
70 Chevrolet=Obsession
I don't know from personal experience, but I have read a lot of threads about this problem. What it all seems to come down to that a lot of different aftermarket companies sell really crappy windshield gaskets and the best one to buy is Precision. Hope this helps.
![]() ![]() ![]() I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
precision is better than some but still not anything to brag about. i went thru three precision gaskets before i got one to fit properly. the first two were too long & bunched up & the glass wouldn't go in. the third had edges that looked like they were trimmed by a guy with a bad hangover. i installed auto glass for over 20 years & if i had a choice, i always recommended steele rubber. they are little more pricey than the imported stuff, but well worth the price for the quality you will receive.
www.steelerubber.com
I called my stockbroker last week and asked him what I should be buying .......... he said "Canned Goods and Ammunition". ![]() |
![]() Join Date: Jun 2007
I don't know if this will help or not, but I had a windshield leak, or so I thought.
Two weeks ago I happen to pull the cowel off and noticed a small seam under the cowel about 3 inches below the windshield. It is part of the cab manufacturing and was sealed with a "rubber" sealent that looked like it was hand applied. The "Rubber" had shrunk and cracked. I climed under the dash with a light and sure enough I could not see daylight, but I could see a rust spot where the water was running in. I sealed it with some clear RTV and pushed it into the seam with me thumb, no more leak.
DIY body and paint work is cheap, making it look good... priceless -------------------------------------------- My Toys; ’26 Ford Model T ‘72 Triumph Spitfire 1500 '09 "The Briggs Flyer" Gettin' High. |
Old Skool Club
![]() Join Date: Jun 2001
Make sure you use an automotive grade of RTV. There's an industrial grade that will cause rust to form and it will be some time down the road before you know. Trust me on this. Here's what you can expect (over time) if the RTV isn't automotive-grade. This is where the wiper motor was installed until it fell out one rainy morning. P.O. had put the RTV around the mounting bolts, thinking he was addressing water leaking into the cab. I have more pix. The damage gets worse. I'll spare you.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#12 | |
I have never heard or seen that before. I will have the cowel off again this fall, it easy and cheap enought to scrape out the RTV and re-apply. I used the Dow-Corning 732. Thanks for the tip!
