08-18-2009, 10:39 AM | #1 |
85 K10 turn signal
Hello Iam 16 and i have a 85 K10.
I would like to know what is needed to fix the turn signal to return to the neutral position after you turn? |
08-18-2009, 11:03 AM | #2 |
Re: 85 K10 turn signal
Welcome -
Either the "turn signal cancel cam" is broken (its a small plastic piece inside the column) or the spring is broken. Parts are available at the "HELP" section of your local auto parts store. Here is a link from the archive on how to fix it. You'll have to pull the steering wheel but once you get it apart I think it will be obvious what to do... When I fixed mine I used the same cancel cam and just replaced the missing spring. Feel free to ask any follow up questions if you have any after you get it apart. K http://67-72chevytrucks.com/vboard/a.../t-170697.html
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 08-18-2009 at 11:05 AM. |
