Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 08-18-2009, 03:20 PM   #1
cochino12
It followed me home?
cochino12's Avatar
Can you help me with my avatar please?
Somebody here made my avatar for me a few years ago but I have gotten rid of those trucks since. Can anyone do the same thing with the three trucks I posted? Thanks in advance
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 08-19-2009, 08:44 PM   #2
19GMC63
19GMC63's Avatar
Re: Can you help me with my avatar please?
best I could do adding a third pic and keeping it under the forum limits. (which is 43.9kb for supporters, right?)
Also did a normal transition instead of the cheesy diamond one.
19GMC63 is offline   Reply With Quote
Old 08-19-2009, 10:14 PM   #3
cochino12
cochino12's Avatar
You are the man!!!! Thank you
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 08-19-2009, 10:17 PM   #4
19GMC63
19GMC63's Avatar
I see it resized it down one pixel to 99 pixels which caused it too freeze. Lemme see if I can fix that.
k, try this one:
if this one doesn't work, try saving it to your computer first then upload it to the board. If you did that in the first place, then try to enter the URL in directly.
Old 08-19-2009, 10:27 PM   #5
cochino12
cochino12's Avatar
k, try this one:
Andrew thanks for the help, when I enter the url it says remote file too large
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 08-19-2009, 10:22 PM   #6
foosed
foosed's Avatar
what do you save it as. also are you using adobe imageready?
1970 c/10 swb (show truck)
1972 custom/10 deluxe 4x4 (restoration pending)
2011 silverado ecsb z71 (daily driver)
foosed is offline   Reply With Quote
Old 08-19-2009, 10:25 PM   #7
19GMC63
19GMC63's Avatar
all animated avatars are .gif format, and must stay that way to stay animated. Yes, I use Imageready to animate after I resize/edit the pics in photoshop.
Old 08-20-2009, 03:24 PM   #8
foosed
foosed's Avatar
Thanks alot! Got it figured out now. Got one more question though, how do you get the transitions between the frames?
Old 08-19-2009, 10:31 PM   #9
19GMC63
19GMC63's Avatar
Ok, it sounds like I can have a larger file size av as a mod.
What does the note say under the box where you upload the avatar? Should say something like "The maximum size of your custom image is X by X pixels or X KB (whichever is smaller).
Old 08-19-2009, 10:35 PM   #10
cochino12
cochino12's Avatar
Note: The maximum size of your custom image is 120 by 120 pixels or 34.2 KB (whichever is smaller).
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 08-19-2009, 10:37 PM   #11
19GMC63
19GMC63's Avatar
ah ha, that's why. See, for me it was 43.9 KB.
Let me see if I can drop it down without losing too much quality. Worst case scenario, you make have to pick 2 of the 3 trucks to use.
Old 08-19-2009, 10:58 PM   #12
19GMC63
19GMC63's Avatar
Ok, let's try this again...
Old 08-19-2009, 11:06 PM   #13
cochino12
cochino12's Avatar
Thats it! thanks again I appreciate your time
Adam
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 08-19-2009, 11:10 PM   #14
19GMC63
19GMC63's Avatar
Cool, no problem. Glad you like it.
Old 08-20-2009, 03:57 PM   #15
19GMC63
19GMC63's Avatar
the quickest and easiest way is to use the tween button in the animation pallete. It's before the new frame button... looks like 4 dots in a diagonal line. There you can set how many frames you want the transition and how the transition is made and whatnot.
