Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 08-20-2009, 12:29 AM   #1
KMACD71
KMACD71's Avatar
Speakers popping
I have speakers in my doors and they started making a pop noise when I power up or turn off the stereo. The sound quality fades in and out. I am trying to narrow down the causes and have started with the ground. The previous owner had the stereo ground(black wire),grounded to the fuse box screw. I tried to ground it to the wiper motor screw and can't seem to get sound from there. Am I going in the wrong direction here? Could it be speaker related instead of ground related. Any advice would be appreciated.
KMACD71 is offline   Reply With Quote
Old 08-20-2009, 04:29 AM   #2
AceX
>130dB Moderator
AceX's Avatar
Re: Speakers popping
I doubt its speaker related. get a ground that isn't really attached to anything that might be intermitant. Look for a grounding point on a bracket somewhere.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 08-20-2009, 10:11 PM   #3
KMACD71
KMACD71's Avatar
I was messing with the wires again .To my surprise while testing the sound with the ground wire not attached anywhere, I am able to play music. Is this normal or is black wire not my ground? Also I am still getting the pop or bass boom when I change stations,switch to C.D. or turn the unit on or off. Sounds good otherwise.This isn't a new install, it's been running fine up until a few days ago.
Old 08-21-2009, 07:09 PM   #4
AceX
>130dB Moderator
AceX's Avatar
the pop you hear is from the amp, be it in the deck or external. There's a pop sound when the amp turns on or switches sources.
I'm going to go look into it a bit more right now. Get back to you soon.
Living Life @ 130dB
RIP El Jay
