Old 08-22-2009, 06:30 PM   #1
Hart_Rod
Hart_Rod's Avatar
Question Big block motor number question....
Is this a desirable motor?
Head casting number 3931063
Head date code F-25-8 June 25,1968
Block Casting number 3935440
Block date code G-16-8 July 16,1968 (Hard to read but fairly certain I'm reading it right)
Info on deck pad..T0712IV
Engine assembled in Tonawanda, NY on July 12 396 325 HP 4bbl. It came out of a Impala
Inputs greatly appreciated.
Hart_Rod is offline   Reply With Quote
Old 08-22-2009, 09:04 PM   #2
mclairmo
Re: Big block motor number question....
Heads are 65-69 325/350/385 & 390 HP 396 with 96.4 cc chambers, 2.06/1.72 valves. Block is 68 396 with 9.8 deck height and 4.094 bore. I have this same basic engine in my Camaro and it runs great. It's desirable but not necessarily rare. Better than a truck block though for horsepower.
mclairmo is offline   Reply With Quote
Old 08-22-2009, 11:09 PM   #3
Hart_Rod
Hart_Rod's Avatar
Thanks for the info. It's a running long block with only 500 miles on a rebuild. What's it worth?
Old 08-23-2009, 12:35 AM   #4
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Why is it better than a truck block? What is the difference?
prostreetC-10 is offline   Reply With Quote
Old 08-23-2009, 06:47 PM   #5
gcburdic
Restoration Virgin!
gcburdic's Avatar
Ummmm...could this be what I think it's for??
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 08-24-2009, 12:50 AM   #6
mclairmo
Truck blocks have a 0.4 inch taller deck. Truck blocks, therefore, require a special wider truck intake manifold. Also, GM made a 366 truck block with a 3.935 inch bore. Truck heads are marked "TRUCK" and have very small intake ports, thus the "peanut port" moniker. Won't support top end horsepower.
Old 08-24-2009, 08:19 AM   #7
gcburdic
Restoration Virgin!
gcburdic's Avatar
Hey Hart....Since no one has answered your question yet, I'll start things off...
I'd say it's worth $800...
Geoff with a G
Old 08-24-2009, 09:26 AM   #8
prostreetC-10
My Carbon Footprint
Okay.....I thought something was up. You are talking about a "tall deck" motor. The problem is that his motor is a 396. The tall decks were 366 and 427. They didn't make a 396 tall deck motor. Your phrase "truck motor" was what confused me. A lot of car motors will have casting letters that say "HI PERF TRUCK" inside the bell housing area.
Old 08-23-2009, 08:56 PM   #9
Dave
DND Trucks
Unless this is a 4 bolt main 396 block, essentially there is no difference between truck or pass. car. The 440 casting number was the first block to use dowel pins for the timing chain cover. Production ended in Aug of 1968.chevy:
Dave is offline   Reply With Quote
Old 08-23-2009, 09:25 PM   #10
Hart_Rod
Hart_Rod's Avatar
Possibly......
It's a 4 bolt. WIW?
Old 08-23-2009, 11:33 PM   #11
prostreetC-10
My Carbon Footprint
That was my thinking but I thought I was about to learn something.
