The Hammer Man
![]() Join Date: Oct 2006
How to identify my rear axle and gears?
I believe i have an aftermarket rear axle and diff but how to know what it is exactly is my question.
It has several casting markings around the outside of the chrome 12 bolt cover, if i post these numbers would you be able to tell? I want to switch to 5 bolt (its 6) so i can purchase the wheels i like but i want to keep the same gearing and if i sell this set up i'd like to know what i'm selling. After reading many posts i dont believe it can simply swap the axles but i'm not sure
Boise69. Bought in Boise ID and its a '69 ___________________________________________ 1969 Chevy C-10 SWB 350/400 - drivable project www.americanhammer.com 2013 MBZ Sprinter customized 2005 MBZ Sprinter Van 2004 Land Rover Discovery 2001 Yamaha Road Star 1997 MBZ E420 1989 Ferrari Mondial T |
Re: How to identify my rear axle and gears?
It's better if you can post up some pics. of the differential. If it has an aftermarket carrier or ring and pinion then most likely the numbers on the outside aren't going to tell you much. What you'll need to do is pull the rear cover off, and check for the stamped numbers on the ring gear. you can also see what type of carrier you have also. After ding so take some pics and post them up so we can look at what you have, and tell you for sure.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
P.S. if all your wanting to do is swap to 5 lug. take your existing axles out, take them to a reputable machine shop, have them re drill for 5 lugs, and reinstall. You can either get the drums from a 5 lug or have them drilled as well, because IIRC the brake components are the same from 6 to 5 lug.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! Last edited by BarryB; 08-23-2009 at 01:37 PM. |
#4 | |
The Hammer Man
