Old 08-23-2009, 08:48 PM   #1
astrochimp
My '63 Chevy
Got my truck last Tuesday. Been trying to fix the last owners "work".
more photos-
http://s185.photobucket.com/albums/x...photo/Samurai/
It has a 305 3sp. tires are 295/55/15
So far, I have
rebuilt the carb, po installed an electric fuel pump "just to get it started"
removed the electric pump
repaired wiring- hardest was fixing where it was cut at steering column connector
swapped steering column with one from a junk yard YEA turn signals!
turned headlight right side up. yes they can be installed sideways.
adjusted timing
painted grill black
repaired clutch rod (bent back strait, removed washers)
sprayed undercoating on back wall and gas tank
removed wire under hood that ran back all around, was spliced 3 times and hooked to 12v+ at each end.
Cleaned painted new q-jet intake
installed seat from 89 Chevy truck, also carpet for back wall, and seat belts
started scraping paint from dash.
I hit a junkyard Friday, got a intake and q jet for $50 and a steering column from a 63 3/4t for $50. ran the numbers and intake is from a 71 Vett (& other 270hp 350s) and q-jet is one of the 800 cfm versions. I wondered why he dug threw parts for so long to find the "right one" for me.
Picked up the seat and seat belts today for $60 Everything is a nice easy fit
Back wall carpet should help noise some. Need to pick up bolts to belts Monday and make backing plates.
And take more photos.
Plans are for a quick cheep semi gloss paint job, with a pearl white top, some ghost flames and stuff. getting the POS wheels & tire off, installing spun disk.
I know original!
David
astrochimp is offline   Reply With Quote
Old 08-23-2009, 10:49 PM   #2
65ona90
65ona90's Avatar
Re: My '63 Chevy
Good looking truck. Sounds like the de-bugging going well. The only thing to watch out for on those old Q-jet 4 barrels is the were the throttle shafts go through the base plate (the shafts the four butterflys are bolted too) can get wore out, causing rough idle, hasitations, and rich/lean conditions. As long as those are solid sounds like its gonna be a great running '63! Keep us updated!
'65 C10 Body/'90 C3500 Driveline
'69 Chevy Nova SS (restored street/strip)
'66 Chevy II/Nova Gasser (work in progress)
'53 Chevy 210 Sled
'79 Chevy K5 Blazer (work horse)
'05 GMC Canyon
**It's worth putting money into as long as it wears a bowtie**
65ona90 is offline   Reply With Quote
Old 08-23-2009, 11:05 PM   #3
Eagar1
Re: My '63 Chevy
Q-Jets are great, and besides the base plate issue is the lead plugs start leaking, best to drill it out and put epoxy in there. I think Muscle Car had a bit on how to rebuild old Quadrajets, may be able to look it up online, or order it.
Eagar1 is offline   Reply With Quote
Old 08-24-2009, 12:53 AM   #4
Captainfab
60-66 Nut
Re: My '63 Chevy
Welcome to the board
Looks like a good truck to work with in spite of the issues you've had.
Keep us posted on your progress
Old 08-24-2009, 12:12 PM   #5
MacAttack
283 Drama Queen
MacAttack's Avatar
Re: My '63 Chevy
WELCOME to the Looney Bin!
Mac.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 08-25-2009, 06:41 AM   #6
astrochimp
Re: My '63 Chevy
Got the seat belts done (except shoulders) last night and seat back in. I made backing plates from 1/8 steel 2" x 3" for the belts.
seat before-
after-
Tan and comfort vs blue nasty, that was held in with lag bolts and wood. Or $60 well spent.
Carpet from truck seat came from. This was on the back wall, I got it and the push pins, installed by holding in place, drill for push pins. Easy. It had rubber mat & sound deadner on the back should help noise.
Got the turn signals working, & wired in temp horn button so it is time for inspection. My 'new' steering column show in 2nd photo. No lump as it was from a factory floor shift.
I ordered a small sand blaster. Its the size of an air brush, hope to use it on the dash.
David
Old 08-25-2009, 07:08 AM   #7
63sbssbbw
UCA63
63sbssbbw's Avatar
Re: My '63 Chevy
OOh
And my favorite color combo too
Looks like your gettin' 'er done Dave
Dave, have you noticed that your knee knocker has temporarily turned into a head basher!!.Man, I've smacked my head on that soo many times LOL
Trent
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 08-26-2009, 06:33 PM   #8
astrochimp
Re: My '63 Chevy
Passed inspection. After new outer tie rod ends.
Also got the electric fuel pump that was supported buy lines only removed and a fuel filter in its place.
Hope to get the license plates Thursday after work.
Old 08-26-2009, 06:48 PM   #9
Bears63
...just another truck junkie..
Bears63's Avatar
Re: My '63 Chevy
Nice lookin' truck. Gotta love these ol' kneeknockers. Glad to see you sprucing her up a bit.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 08-31-2009, 09:18 AM   #10
astrochimp
Re: My '63 Chevy
Not much to talk about. Plates are on been driving some.
I got the inside doors & jams painted,
bought paint for the body,
took it to a car wash that knocked most of the loose paint off,
bought a paint gun- look like a yard paint job!
Today I hope to fix the shifter- PO installed wrong so pattern is 2-3 1-R, first it up and to the right. Also want to trouble shoot the gas gauge.
I found a set of wheels, hope to trade mine for them and $ or just buy outright, but both of us are out of $$.
Wife got the pinstripe fever and ordered a kit. She painted flames on the lawn mower Sunday- VERY good for first set.
Photos soon, battery died in camera last night.
David
Old 08-31-2009, 09:20 AM   #11
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: My '63 Chevy
Nice truck man....
Man, how many 63's do we got here now ??
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 08-31-2009, 12:10 PM   #12
astrochimp
Re: My '63 Chevy
Lawn mower flames-
http://i185.photobucket.com/albums/x...amurai/003.jpg
Still need stripped, not bad for free hand, first attempt.
Hard to see in photo, but gold hammertone with silver hammertone tips.
Old 09-03-2009, 07:39 PM   #13
astrochimp
Re: My '63 Chevy
I promised a review of the mini sand blaster, and have been playing with it for a while so here goes.
Not great as a typical sandblaster- does not remove most paint well.
GREAT as a cleaner, minor rust remover, ect.
This is a Badger model that looks much like a air brush, it uses very fine ($$) grit to blast with. Wife said, I got some baking soda, want to try that? WOW! cheap and effective.
I use a very small air compressor IIRC its 1 hp, made for tire inflation and brad nailers.
This makes a mess. Best to use outside. With the garage door closed!.
Perfect for cleaning electric terminals.
Perfect for cleaning electric terminals. ( yes that good)
Took the layer of black gunk off the steering wheel, but left the white paint.
Took over spray off rubber molding and parking light lens & trim. I used it tonight to remove rust from the bottom of a tinny dent one the hood.
Overall a great buy at about $25.
I picked up a cheep air brush and paint gun last week, wifes pin stripe supplies should be her Friday. Paint is soon, no $ for anything else!
David
Old 09-03-2009, 09:43 PM   #14
Corts60
Just here to tinker
Corts60's Avatar
Re: My '63 Chevy
Much better choice of seats! Great project!
Old 09-09-2009, 08:27 PM   #15
astrochimp
Re: My '63 Chevy
Nobody move or I'll paint this truck!
Long weekend, yellow would scrape off very easy when wet, so removed all from the cab. Did the door jams with a $5.99 air brush, then could not find a connector for paint gun, so just kept painting, until air brush died. Tues evening got the paint gun fired up, did inside the bed and tail gate. Everything needs a 2nd coat, hope for thurs or fri.
Used Valspar Implement paint. Will do a right up when finnished.
A few more photos here-
Old 09-15-2009, 06:28 PM   #16
astrochimp
Re: My '63 Chevy
2nd coat. The light in photo make is look bad on bed.
This paint is sandable, and I was able to primer over a spot.
Paint was $29, Hardener was $12 (saving $ for tires and wheels!)
David
Old 09-15-2009, 06:48 PM   #17
SixOneC10
SixOneC10's Avatar
Re: My '63 Chevy
I'm diggin' the yellow
SixOneC10 is offline   Reply With Quote
