08-24-2009, 12:46 PM | #1 |
Wheel Base 70 SB - U-Haul Trailer
I am picking up a 1970 GMC Shortbed truck and will be towing it home with a U-Haul trailer. Just wanting to make sure it will fit on the trailer?
Thanks,
Dustydog 1940 Ford 2D SDN 1970 GMC SB 2004 C5 Vette |
08-24-2009, 12:56 PM | #2 |
Re: Wheel Base 70 SB - U-Haul Trailer
I put my 68 SWB on a u-haul trailer when I took it to get painted. It was a tight squeeze width wise. The tires had to kindof driver over the outer edges.
My truck has disk brakes on it with rallies (for now). |
08-24-2009, 01:29 PM | #3 |
I picked the truck up in my build thread and it fit on a uhaul car hauler no problem...
go to projects and go to NOT4SLE |
08-24-2009, 02:09 PM | #4 |
Thanks,
we are heading out Tuesday night to pick it up. 1400 miles each way!
08-24-2009, 02:48 PM | #5 |
Stock wheels will fit on the trailer no problem. If the truck has a dished aftermarket wheel, that's usually what causes problems.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
08-24-2009, 03:03 PM | #6 |
Retiredoldfarttankerguy
Hart Rod's, right on the money. I drug #6 from Spokane on a u-haul - it was a LWB 4X4, but the narrow wheels and tires saved me. So have Fun. 1400 miles that's committed! either you are or should be!
________________________________ Swany Current 67-72 truck projo - #5 of 6 and #1,000,000... of all the other things that keep me from working on it. Fav - local parts shop. They ship world-wide. www.fillingstation.com |
08-24-2009, 03:09 PM | #7 |
Thanks,
I think it may be to wide with the wheels that are on it now. But he has a set of stock wheels/tires that I can swap out.
08-24-2009, 04:21 PM | #8 |
its all about the +6 inches
1400 is a good day trip!
08-24-2009, 04:26 PM | #9 |
They make 2 different width car trailers u-haul uses. Try to get the wider one. Also dont tell them your gonna haul a truck or they wont rent it to you, tell them its for a jeep with wide tires and lastly dont go over 55mph as it will start swaying with you and it will jack-knife you. It will handle the weight with no problem. Make sure you chain it down real good, side to side & front to back. Better safe than sorry.
Bob
I BELIEVE IN JOHN 3:16 |
08-24-2009, 09:31 PM | #10 | |
______________
Their weight limit is 4900 lbs, I learned this last night. Last edited by sighlurr; 08-24-2009 at 09:32 PM. |
08-24-2009, 06:31 PM | #11 |
I used a u-haul trailer to get my truck with no hauling problems. Again DON"T tell them it is for a truck! I told them it was 69 Nova. I also used one to haul my 94 Corvette to New York and I may have exceeded the posted speed limit with no problems swaying. However stop and check your chains/straps frequently.
08-24-2009, 08:25 PM | #12 |
Restoring it $200 at a time...
Yep, by their rules, a 3/4T truck is too light to pull a Cherokee. I've brought home several '87 Accords in the last few years.....
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 |
08-24-2009, 08:49 PM | #13 |
Moderator
I am making a road trip next Saturday to pick up my new "project" and am renting a U-Haul car trailer. I told them it was for a 03 Civic.
1400 miles is a haul. Mine is only 500 each way.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 08-24-2009 at 08:50 PM. |
08-24-2009, 08:59 PM | #14 |
Yes it will fit no problem. I,ve hauled longhorns on u-hauls before
