pics of brake booster to aftermarket intake please!
Any pics of how you hooked your brake booster up to an aftermarket carb & intake?
The factory rochester has it threaded in to the carb, an aftermarket carb does not allow this so you have to do it into a port, what insert? what line? what did you use and how? pics please. |
Re: pics of brake booster to aftermarket intake please!
carb should have a large vacum port just hook the hose to that or a fitting on the intake runner. I know hollys and edelbrocks have the large port for either brake booster or pcv valve.
![]() Join Date: Nov 2006
Put a plate under the carb with a inverted flair fitting. Going to 1 port is not as good as going under the carb base.
Bob
I BELIEVE IN JOHN 3:16 |
Or, hook it up to a 90 degree fitting screwed into the manifold like the ones here.
BEn IV was right, There was a brass fitting plug on the back of the carb for it. Got it on and now ran in to another problem. LOL
Ill start a new thread about this one. ![]() |
