suggestions on fuel line fitment
I have this new carb i am finally getting around to installing. The fuel inlet is a dual feed set up and the supplied bracket hits the AC bracketry.
I see one of a couple fixes. A. Put a carb spacer under the carb which may work and provide enough clearance. B. bend the fuel line a bit which would give it a 45* bend and clear the bracket. (seems like the best) C. find a flexible fuel line. If I go with B is their a tubing bender small enough to fit in the available short arm to bend it out accurately on both arms? DoeS anyone else have a suggestion? ![]() ![]() ![]() |
Re: suggestions on fuel line fitment
I like the 1 inch 4 hole carb spacer option. 1 the spacer will help out with clearance 2 it will keep the fuel in the carb from boiling. Just my 2 cents worth.
#4 | |
![]() Join Date: May 2009
I ran into this problem with a SBC (with a Barry Grant carb), ended up shortening the two lines that go to the float bowls but, I can see that the choke coil is in the way on yours. I think that bending the two lines would be a good idea, also.
My goal in life is to be as good a person as my dog already thinks I am - Unknown |
![]() Join Date: Nov 2006
Can you flip the line 180 degrees and feed it from the back ?
I BELIEVE IN JOHN 3:16 |
#6 | ||
Gone to greener pastures
![]() Join Date: May 2007
Personally, I'm more interested with torque rather than HP.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
are those tubes regular steel or stainless? stainless will be a bit difficult to bend
i like the spacer option another option is a 45 fitting on the carb
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 08-25-2009 at 05:34 AM. |
Don't bend that line or you may end up wth peeling, cracking and flaking chrome. Use a carb spacer, will probably help with power and keeping the fuel cooler, too. You can find them cheap on Ebay and some even have a threaded hole for a power brake booster or pcv nipple, which is nice to have it you ever need it.
