Old 08-25-2009, 01:34 AM   #1
vegaschevy
repairing grill surround dents and polishing
I have the grill that is going on my 72 truck. However it is dented in a couple of spots and ill have to fix the dents.
What does everyone do to fix the grill shell dents on these stainless bits?
I have read afterwards I can shoot it with oven cleaner to get the clear coat off. Then slowly polish and sand it back to a nice shine.
ANyone have how tos? pics?
vegaschevy is offline   Reply With Quote
Old 08-25-2009, 01:55 AM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: repairing grill surround dents and polishing
hammer and dolly to get out dents
Oven cleaner to get off the factory ando-coating to get to the bare aluminum.
Then start at 120 grit, and up to atleast 2000 grit. Then buff with a buffing wheel and polish it up. No pictures but that's how most say to do it
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 08-25-2009, 05:35 AM   #3
cdowns
cdowns's Avatar
no stainless there grills are aluminium
Old 08-25-2009, 11:34 AM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Oven cleaner will remove the anodizing, per a restorer I spoke with. Then, it's on to removing the dents.....carefully. Like cdowns said, these are aluminum. Then, like already stated, start with the sanding. You've got to get the surface smooth and that means all the fine imperfections in the surface. There's a polishing compound called Tripoli, that is what should be used after the sanding and dent removal is done. It is designed to work on polishing aluminum. Finish it up with some finer grade of polishing compound and you're done.
As for the cost of having it done just like this method.....I got a price of $500 and up. Time is money, huh?
Member Nr. 2770
