08-26-2009, 02:39 PM | #1 |
PROJECT 7DEUCE
Passenger door lock problems?
I have new latches and new chrome handles on little daisy and every time you close the passenger side door it locks itself? Any ideas on what maybe causing this ?
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-26-2009, 03:32 PM | #2 |
Hollister Road Co.
Re: Passenger door lock problems?
You may have a left side door latch relay on the right side. They have a spring that pushes it back after you pull it up to open it from the inside. Disconnect the relay and see if it still does it.
08-26-2009, 04:41 PM | #3 |
PROJECT 7DEUCE
You are correct it seems however there is a r stamped into the relay but with out it on there the door opens and closes every time with out locking...
