01-12-2003, 12:10 PM | #1 |
Air compressor.What should I buy?
I want to buy a compressor and a sand blaster to do my own sandblasting on my truck. I was looking at a Eagle compressor with 12.5 cfm at 100 lbs. and a 100us sand blaster. Would the compressor be big enough to keep the sand blaster going? Thanks in advance,your advice and experience is appreciated.
67 c20 lwb stepside,327 70 GMC(parts truck) 69 Olds Cutlass(The new baby) 93 silverado 4x4 99 chrysler intrepid 95 ski doo formula st 86 honda 350 4x4 98 Yamaha outboard 25 hp The one who dies with the most toys wins!!! |
01-12-2003, 12:51 PM | #2 |
Used to have a truck
Sandblasters use a LOT of air. If the sandblaster your looking at is a pressure pot blaster you could probably get by with that compressor. If its a siphon type forget it. It wont come even close .
No truck :-( |
01-12-2003, 01:19 PM | #3 |
compressor
I have a 80 gallon vertical two stage that wont make enough air for my 110 pound pot blaster. I think i am gonna buy another and manifold them together. I would recommend something over 20 cfm for blasting.
1967 K30 Napco 292/SM420 original paint 30k miles 1968 K60 Napco 396/5spd. dbl frame 52" michelins 1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks 1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr 1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison. |
01-12-2003, 01:53 PM | #4 |
I would recommend a twin stage 60 gallon as a minimum. This will run most booths, and the small pressure pots (like Harbor Freight sells). I blast weekly with mine. It is an Ingersoll Rand T30
69 SWB LT1/4L60E www.classicplace.com |
01-12-2003, 04:31 PM | #5 |
Here is the link to a similar thread on another board I do. Maybe that'll keep this one shorter...
http://www.hybridz.org/ubb/ultimateb...c;f=8;t=001027
01-12-2003, 09:18 PM | #6 |
Recovering Truck Driver
Don't buy one of those cheapy $400 coleman single stage 6.5 horsepower 60 gallon vertical compressors, I hate mine. It won't keep up with anyting.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
