08-26-2009, 10:00 PM | #1 |
ls wire harness
I just got a 6.0 with the factory wire harness and ecm. I didnt realize how much wire harnesses there is on one of those things. Is there a wire harness made that I could use with the factory ecm that would be just the engine controls and nothing else?
1970 c20 converted to c10 sleeper 1979 c20 the wood hauler 1991 honda civic daily driver spray and pray baby |
08-27-2009, 03:54 PM | #2 |
Re: ls wire harness
you can send the harness you have to nelson performance in san antonio and they will remove all uneccesary thing. makes it supper clean and easy
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
08-28-2009, 05:11 PM | #3 |
Next project: 1970 K10
Re: ls wire harness
Jesse at www.wait4meperformance.com can rework your existing harness to a stand alone, remove all the unneeded wiring and connections, and tune the PCM to delete all the unneeded sensors and remove VATS for $360. Just got mine back, about 1 week turnaround. I've used Jesse for several years now for tunes, never a problem. About a dozen wires to connect, everything else is plug-n-play.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 08-28-2009 at 05:13 PM. |
08-28-2009, 08:58 PM | #4 |
Re: ls wire harness
and thats to run the factory injection right?
08-28-2009, 09:11 PM | #5 |
Re: ls wire harness
yes factory injection they can also remove o2 sensors for cat deletes and other things just tell them what you want or ask what they suggest. i have used bothe pcm4less and nelson with success
08-28-2009, 10:49 PM | #6 |
Re: ls wire harness
The pic I posted is the original harness from the 2006 Silverado donor truck that has been reworked. Things that are not needed for a stand alone swap operation is removed, like the rear O2 sensors, EVAP, EGR (if equipped), etc.
And yes, I am running the original truck injection setup, for now. The engine will go in my 85 just as it came out of the 2006, just prettier!!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
09-19-2009, 02:41 AM | #7 |
Re: ls wire harness
WOW thats nice!!!!!!!!!!!!!!!!!!!!!!!!
Once a Marine Always a Marine OOH-RAH GM Fanatic 1982 K20 4" Rancho lift 350cid, edelbrock performer intake 1405 carb, hedman headers, TH350, " Wheres the MUD!!!!!!!!!!" 1986 c30 camper special 454, th400 (for sale) 1984 K10 Big Ten (project) needs motor 1984 C10 355, 700r4, (project) needs shortbox bed |
