Old 08-27-2009, 07:49 AM   #1
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
12 Bolt Rear End with Posi What Oil to use?
Ok just like the title says I have a 12 Bolt with Posi. What oil should I use on my rear end? Is regular oil ok or can I use Synthetic what Weight? Also Should I change it, the truck has been sitting for over a year and leaked alittle just enough to leave a small quarter size stain..How hard is this to do for someone who's never done this job before? Also since I will have the differential cover off how can I tell what gears I have?
Thanks Pablo...........
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 08-27-2009, 07:56 AM   #2
crawdadfox
crawdadfox's Avatar
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
Re: 12 Bolt Rear End with Posi What Oil to use?
Use a quality standard gear lube along with GM limited slip additive. When you have the cover off there will be numbers stamped on the side of the ring gear...like 41:10...divide the smaller number into the larger one and that will give you your axle ratio, its easier than counting the teeth on the ring and pinion.
Down......with the sickness!!
crawdadfox is offline   Reply With Quote
Old 08-27-2009, 08:01 AM   #3
rwolf9653
more ideas than money
rwolf9653's Avatar
To tell what gears you have you can count the teeth on the ring gear and count the teeth on the pinion gear. Divide these two numbers and you get you ratio.
As for the gear oil you can use regular 80W90 as long as you put in the additive for the positraction. I prefer to use Amsoil.
Randy
1948 Chevy 3100 5 window
1966 Chevy C30 Dually
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1972 Chevy K5 Blazer
1987 Chevy V10
2003 Chevy Suburban
rwolf9653 is offline   Reply With Quote
Old 08-27-2009, 08:47 AM   #4
cdowns
cdowns's Avatar
royal purple no additives needed for posi units
Old 08-27-2009, 08:58 AM   #5
Green Machine
Green Machine's Avatar
We use Royal Purple synthetic without any additives. It has mild posi snap/chatter going around corners in town. Our Son (19) drives it and likes the mechanical feel of the posi sticking so we have not put in any additives. Royal Purple bottle states that it is for posi rear ends, so the lube should be ok.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 08-27-2009, 12:24 PM   #6
smokekiki
Mike
smokekiki's Avatar
I run Royal Purple with Ford limited slip additive. Without the additive and new discs in my LSD it was chattering.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 08-27-2009, 01:15 PM   #7
vegaschevy
I run wal mart brand gear lube with GM additive. It has all the qualifications and specs and passes GREAT with tests.
vegaschevy is offline   Reply With Quote
Old 07-03-2015, 05:15 PM   #8
67 chevelle
67 chevelle's Avatar
The ford additive is what I use also ,,, man does it stink ,, it has solved "issues" for me ,, clunking around corners
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 08-27-2009, 01:33 PM   #9
Ackattack
Ackattack's Avatar
I know my new Eaton posi said specifically not to use synthetics.
also, counting the pinion gear teeth sounds easier than it is. It's basically blocked from view by the diff. Look for the stamp on the ring gear.
Ackattack is offline   Reply With Quote
Old 08-27-2009, 02:18 PM   #10
piecesparts
Parts and more parts
piecesparts's Avatar
I have run synthetic lube with my Eaton posi, but switched back when we got to reading further in the data sheets. I always use the additive, since the dealer put lube in my 95 Impala SS without the additive and it chattered really bad. Small price to pay for protection. I have Eaton posi rearends in all of my trucks.
Old 08-27-2009, 02:48 PM   #11
mr48chev
mr48chev's Avatar
Good quality 80-90 and unless it specifically says that it is made for limited slip aka posi run the posi additive.
mr48chev is online now   Reply With Quote
Old 08-27-2009, 04:51 PM   #12
lilred67
lilred67's Avatar
i run mobil 1 85/90 full synthetic with gm diff. additive. mine chattered without it.....
lilred67 is offline   Reply With Quote
Old 08-27-2009, 07:17 PM   #13
70c10
67-72 Addict!
70c10's Avatar
The directions for my eaton posi said not to use synthetic.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 08-27-2009, 10:45 PM   #14
petey-pablo
"THE GREEN GOBLIN"
I was going through the copies of some receipts I got from the PO and I found one from a Local Speed Merchant Dated FEB/16/06 that apears to be for the rearend posi unit it reads "EAT19556 12T GM HD 3.73 & POSI" Is this a good unit? I think I should plan on getting a diff cover with a drain plug as well to make this easier
Thanks guys
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 08-28-2009, 11:16 AM   #15
piecesparts
Thanks guys
I have been running an Eaton rear end posi unit in my 84 GMC for the beter part of 12 years. It was in the truck when I purchased it and since then the speedo has turned over twice. You have a good unit. You are right when Eaton built these in the early years there was no such thing as synthetic oils, but Eaton stilkl exists and the info is from the recent years, they do not like a synthetic in their units. I have run synthetic in one of mine (91 daily driver with 275,000+ miles) and have had no issues, though.
Old 08-27-2009, 11:11 PM   #16
capev86
they didn't really have much for synthetic fluids when these axles were being built. the additive certainly can't hurt if you have a limited slip. but the rear diff gets pretty hot, so the synthetic is a good idea especially if you work your truck. mobil 1 and others make economical gear lube that is good for an average joe car, but i will be using royal purple gear 80w-90 in my 72 burb 3/4 ton with HO52 axle when i change to a 4.10 gear.....hopefully soon. already have royal purple manual trans fluid in the saginaw 3 on the tree. its worth the money for a vintage truck that will be used as a truck.....aka.....heavy duty towing on occassion! my dad put royal purple in the '84 burb 10 bolt when he swapped it into his 87 burb (3.73 gears are soo much better than 3.08)
capev86 is offline   Reply With Quote
Old 08-28-2009, 11:57 AM   #17
capev86
yeah....use good fluid and they last a long time.....not good if you are in the business of making money on repairs. regular fluids don't take the heat and abuse like synthetics.....the rear axle is one place that gets pretty warm and is often neglected during maintenance cycles.
Old 07-03-2015, 11:34 AM   #18
Coursey
Coursey's Avatar
I am not sure what type of oil is in the rear end. It is a posi. What type of oil is safe to top off the oil level?
Coursey is offline   Reply With Quote
Old 07-03-2015, 04:35 PM   #19
'68OrangeSunshine
'68OrangeSunshine's Avatar
Any good gear oil, SAE 90 [or a multi-viscousity in that range] that is rated GL-5 for limited slip. I also add the GM Posi ''Whale Oil'' additive.
Old 01-03-2019, 02:42 AM   #20
KMAT
Will it damage anything if I use Carquest 80 90 mixed with partsmaster 8090 and some trans-x posi-trac lube
KMAT is offline   Reply With Quote
Old 01-03-2019, 05:08 AM   #21
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Shouldn't hurt anything but why mix? The 12-bolt only holds like 1-3/4 quarts so 2 quarts of any MP GL-5 Gearlube with 4-6 oz of posi additive your good to go. FelPro cover gasket #13391. Pop the cover and inspect the old fluid for fleck and friction plate pieces, busted ring gear teeth, etc...If everything looks good button it back up and refill with 80w90. Mix the full 4oz bottle of posi additive with the first quart of gear lube and squirt it all in. Fill until lube begins to run out the fill hole and install the plug. On old factory Posi units that were broken in with mineral/dino oil, I use the old school mineral oil because thats whats in those frictions. New units with the carbon fiber frictions it's ok to use synthetics. I use this https://petroleumservicecompany.com/...-1-quart-case/ with this in my posi's https://www.summitracing.com/parts/a...SABEgKSJvD_BwE never had an issue yet.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
