08-27-2009, 05:34 PM | #1 |
What should i cut coils with?
im about ready to cut my coils for a 3inch drop
and im not sure what to use ive heard do not to get them hot or use a torch cutting wheels ive heard will a saw za do it? and how many coils ive heard a coil and a half will do it.
Smoking Tires Since 1992 1969 c10 AKA SIN 1985 SSWB TRAZER (super short wheel base) Last edited by threeonthetree; 08-27-2009 at 05:36 PM. |
08-27-2009, 05:50 PM | #2 |
Nothing to see here.....
Re: What should i cut coils with?
cutting wheel. just make sure you take your time and let don't allow the coil to get too hot in the cut region. slow is the way to go.....
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
08-27-2009, 05:56 PM | #3 |
Cutting wheel and keep the metal cool, maybe wrap the bottom of the coil with a wet towel or submerse bottom of coil in a bucket of water; just don't eletrocute yourself. I always thought that you cut one coil per inch of desired drop. Someone please correct me if I am wrong.
08-27-2009, 06:04 PM | #4 |
I know it can be a pain to remove and install the springs, but I would recommend cutting one coil, reinstalling, and driving for a week to let it settle. See if that's enough. If not, pull them out and cut another coil, or even a half coil.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
08-27-2009, 06:23 PM | #5 |
I wouldn't worry about heat build up using a cut off wheel.
08-27-2009, 06:59 PM | #6 |
low n' slo
agree. i think a cut off wheel would be best since a coil isnt that big across and dont produce a whole lot of heat. at least not enough to mess anything up.
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
08-27-2009, 07:08 PM | #7 |
User #12137
i used a band saw and cut 1 1/2 coils the first time and it was way to low the 2nd time i cut 1 coil and it was just rite its about 31/2 or 4 inch lower in the front now
i had to also cut the metal stand and the bump stops off both lower control arms and replaced them with Energy Suspension bump stops Last edited by tnblazerk5; 08-27-2009 at 07:14 PM. |
08-28-2009, 10:42 AM | #8 | |
My Carbon Footprint
Just had to take a shot at a funny this morning. Reminds me of the ferrari testy mirrors. Nice stance, buy the way!!! |
08-27-2009, 07:49 PM | #9 |
remember! cut less than you think you'll need! just a half a coil brings these springs down quite a bit.
08-27-2009, 08:04 PM | #10 |
Nothing was mentioned about rear springs. Remember that you cannot cut the rear springs. You didnt say front or back so this is just a reminder that they can't be cut.
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
08-27-2009, 08:15 PM | #11 |
What he said.....on che cheap, you can run a 2 " block on the rears. best of luck
http://community.webshots.com/user/hotrodhorn |
08-27-2009, 08:28 PM | #12 |
08-27-2009, 08:11 PM | #13 |
Toss the coils upside down in a 5 gallon bucket of water, torch 1 full ring off the bottom.....after the springs "settle in", you will have a 3" drop crazyAl
08-27-2009, 09:07 PM | #14 |
low n' slo
why can't u cut the rear springs? not questioning u, I just never knew that
08-27-2009, 09:11 PM | #15 |
Watch out for your cornhole !
Because the coils get tighter on the ends. If you cut the ends off, the coil retainers won't fit into the ends of the spring to hold them in.
08-27-2009, 09:28 PM | #16 |
its all about the +6 inches
i've used a torch, sawzall, and cut off wheel.
Cut off wheel is prefered IMO. Heat is second, if you now how to ue a torch, then you won't heat it up enough to do any damage. (that 'damaged from heat' is WAY over rated, you'd have to be a real tool to damage them if lowering with heat alone) Sawzall is last on my list just due to being a bit harder to control. |
08-27-2009, 09:46 PM | #17 | |
http://community.webshots.com/user/hotrodhorn Last edited by 69 longhorn; 08-27-2009 at 09:47 PM. |
08-27-2009, 10:07 PM | #18 |
well, we had this fuel truck in the shop one time... and I figured, *heck* I'm working on the front of the *darn* truck... I ain't scared.
Yeah... I almost crapped myself when i saw the flames out the corner of my eye... under the cab. Been there, done that. First time I tried welding sheet metal was a striker post on an international 4900 fuel truck. (anyone notice a trend here?) The funny thing is, the back wall of the cab has a panel covering the lower part of the wall, under the window... and insulation in there... yeah, i blew through, and it cought fire... and again, I almost soiled my pants. |
08-27-2009, 10:38 PM | #19 |
well i used the cut off wheel and it went faster than i thought
so this is where im at now which i want to be lower how long will it take the springs to "settle in"? im sitting at 31" or somthing and i my rear is gonna be like 29" when i get the drop should i take a half coil off?
Smoking Tires Since 1992 1969 c10 AKA SIN 1985 SSWB TRAZER (super short wheel base) |
08-27-2009, 10:46 PM | #20 | |
08-27-2009, 11:43 PM | #21 |
How much did it drop it?
08-28-2009, 12:41 AM | #22 |
i didn't take a measurement before i wasn't thinking and i already had it on the jackstands and both wheels off b4 i remembered to.
what is a stock ride height from fender to the ground? mine is at 31'' now.
08-28-2009, 08:27 AM | #23 |
Mine's at 32 1/4" front and 31 1/4" rear. Both measurements to the center of the fender opening above the wheel centerline.
