08-28-2009, 04:03 PM | #1 |
Thermostat Bypass Housing Help
I'm having a hard time finding the inlet/spacer located below the thermostat on my '66 327. Does anyone happen to have a part number, or at least what it is officially called? Looks like the inlet is for the bypass, although not 100% on that either.
Details: 1966 C20 327, 99.99% original Short water pump Thanks, Jay |
08-28-2009, 04:48 PM | #2 |
Senior Enthusiast
Re: Thermostat Bypass Housing Help
Interesting, I'd never seen or even heard of a bypass on a small block Chevy.
All I have to go by is the 1960 Chevy truck shop manual - on page 8-115 they do show a line drawing of a system similar to your picture. Apparently what you're looking for is called the Bypass Thermostat Housing. On page 8-116 there's brief disassembly instructions under the title: Thermostat by-pass cooling system (Connections for Engines Equipped with Automatic Transmissions). I tried Google, EBay and Ecklers and don't find anything under bypass thermostat housing. This has got to be a rare piece. |
08-28-2009, 05:11 PM | #3 |
I Got it BAD!
That's a cool rare part... What's wrong with it besides the broken bolt? You can buy a 1" spacer that is threaded with one or two outlets at summit or jegs. CPP also makes one. Although it's not needed... you could just remove it and plug the waterpump housing.
Build Thread: http://www.chevyguys.com |
08-29-2009, 02:12 AM | #4 |
60-66 Nut
It seems to me those were more common on Vette's. As was already said, you really don't have to have that, as there is already a smaller thermostat bypass internally. You would just need to plug the port in the top of the water pump. Unless of course you want to keep the truck original if it did come that way from the factory. I haven't seen one on an original truck that I can remember.
08-29-2009, 03:28 PM | #5 |
Thanks for the replies, almost glad to hear that its rare/wierd and im not just totally overlooking something stupid.
@markeb01- Thanks for looking through that book; I only have the 63 and 66 manuals. The name will give me something to run off of. @chevyguys- nothing is really "wrong" with that part- missing some iron in areas due to 40 yrs of water sitting in it. The bolt that broke looks like it will not be fun to get out- water has been leaking around it for some time. Push comes to shove I can bore the whole thing out.. @Captainfab- Thanks for the Vette connection; just got off the phone with a friend of mine who has a 66 Vette and it does have something very similar. I'm going to do a little more digging on it while I wait for a few more parts to come in, and if nothing, put a plug in the water pump. Thanks, Jay |
08-31-2009, 02:11 AM | #6 |
Time to upgrade to an aftermarket intake, good used ones are really cheap.
Can't you lift the housing off over that bolt, exposing the rest of it? If it won't come out, just weld a stud to it, and grind it enuff to slide back down and use a nut and washer? |
12-06-2019, 12:13 PM | #7 |
jrocket567, hope all been good. Well I came across this old post and found it interesting as I too have the same set up on my 1967 327, can't say I ever seen one myself or just never recognize it. Well in the interest of keeping my engine and bay area looking stock, I was wondering if you or anyone out there might of got more info on the uses of this thermostat bypass housing.
Thanks in advance to you and all . NGN Nick |
12-06-2019, 07:01 PM | #8 | |
The purpose of the bypass is to allow some coolant to circulate through the engine even when the thermostat is closed. That continuous circulation helps avoid localized hot spots. As Captainfab mentioned in an earlier post, the small block V8 already has a smaller bypass opening built into the block & water pump ... it's the extra hole on the passenger side below the lower mounting bolt. Although, I believe this passageway was blocked off with a metal dowel rod in the truck applications with the external bypass adapter / hose. I've also noticed that the pick-up truck applications used a single bypass hose running from the adapter to an elbow fitting on the top of the water pump. While the larger truck applications used two bypass hoses going into a tee fitting on top of the water pump. The same bypass adapter was used for both so the pick-up truck applications have a pipe plug threaded into that unused hole on the driver side of the bypass adapter housing. |
12-07-2019, 12:37 AM | #9 |
I have a 1966 parts truck with the four barrel and that bypass it is a factory set up. You just don’t see very many of them.
Posted via Mobile Device |
06-04-2020, 05:44 PM | #10 | |
basic membership on the forum comes with no charge. You may post a reply in any of the Classified Forums. You will not have the ability to offer items "For Sale", "For Trade", or make a "Wanted to Buy" or "What's it Worth" post. Your basic membership includes the following- Registered Member : free All members registered to the message board. As a registered member you can- Post new threads and replies in message areas. Post replies only in classified areas. Upload photos to the photo gallery. 50 PM storage after XX Posts 100x100 avatar size If you are the "Occasional" seller that is just cleaning out your surplus of parts left over from your build, you will need the Premium Member subscription. This will allow you access to start threads in any of the Classified forums. Your Premium Membership includes the following- Premium Member: $25 per year, $15/ 6 mo As a Premium Member you enjoy all the benefits of a Registered member. You have the advantage of- Premium Member banner under name Bold Blue name color Access to post in our classified system. Limited to occasional selling of leftover parts larger signature 175 PM storage 120x120 size avatar Upload animated avatars Upload photos to photo gallery Upload photos to profile and create albums in profile (personal galleries) Ability to change user title Post visitor messages Create social groups Post events to calendar View who's online Set self invisible Last edited by The Rocknrod; 06-04-2020 at 07:27 PM. |
06-04-2020, 07:15 PM | #11 |
Sorry sold it on the for sale side of the forum.
06-05-2020, 11:32 AM | #12 |
