08-30-2009, 09:35 PM | #1 |
1970 Daily Driver
Heater Core Supply?
It is the hose coming from the water pump that supplies the heater core with hot water right? I am putting a shut off valve in and don't want it to be on the wrong line allowing hot water into the core when I am using my a/c. Thanks
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. Last edited by lts70; 08-30-2009 at 11:23 PM. |
08-30-2009, 11:21 PM | #2 |
1970 Daily Driver
Re: Heater Core Supply?
I just looked at the Vintage air online diagrams and it says to put the valve on the intake manifold side hose and not the water pump side. I am glad I looked at the diagram first, I thought it would be the water pump side for sure.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
08-31-2009, 01:14 AM | #3 |
I'll just verify for you, the water comes out of the intake, the same passage that goes to the thermostat and OUT to the radiator, the intake side uses the small 5/8 line and the 3/4 return goes to the pump.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
