08-31-2009, 05:04 PM | #1 |
Not too old to learn
Firewall hole what?
Next to the steering shaft is a hole, I think must be for a manual shift rod. My truck is an automatic, but hole is there. Could this have been a manual shift at one time, or is there a factory delete plug or cover?
1968 C10 a way to long restoration. |
08-31-2009, 05:19 PM | #2 |
Active Member
Re: Firewall hole what?
Someone posted this sometime back. You probably can make one or order some rubber plug that used to go in those holes.
08-31-2009, 05:48 PM | #3 |
On the fast track to nowhere..
It should have had a metal plate with rubber backing held on with 2 screws covering it up for auto.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
09-01-2009, 12:47 AM | #4 | |
So I'll look for a metal/ rubber plug.I wonder if it might be one that has metal fingers that snaps in place. I didn't see any screw holes in the body.
09-01-2009, 02:54 AM | #5 | |
"THE GREEN GOBLIN"
Edit added pictures Here are two pictures of my fire wall where you can clearly see the holes for the two screws...I forund theses pictures here on the board from other posts So I will still get you a picture of the Metal plate that goes there some time today.
Petey-pablo
"THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi Sold Drive it like you stole it! Petey-pablo@sbcglobal.net Last edited by petey-pablo; 09-01-2009 at 03:10 AM. Reason: Added picts |
09-01-2009, 12:41 AM | #6 |
Thanks for the input . Clutch linkage, that makes sense.
So is it a rubber plug? That fills the hole.
1968 C10 a way to long restoration. Last edited by 8door; 09-01-2009 at 12:42 AM. |
09-01-2009, 05:41 AM | #7 |
Since 8door's truck is a 68 the hole cover would have been a plastic snap in plug. The plastic plugs are not available so the metal plug can be used. The two mounting holes will have to be drilled. #6 hex head sheet metal screws 1/2" long is what is used in the 71-72 trucks.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
09-01-2009, 07:48 AM | #8 | |
"THE GREEN GOBLIN"
Petey-pablo
"THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi Sold Drive it like you stole it! Petey-pablo@sbcglobal.net |
09-01-2009, 09:31 AM | #9 |
Well firewall info is good I'm learning more from the pictures than just the "clutch linkage hole." Sounds like a conversation with a Proctologist
09-01-2009, 10:34 AM | #10 |
Ditto
09-02-2009, 10:45 AM | #11 |
I have a 1970 4x4 chevy that has never converted still has original automatic tranny but i have no plug and no plate screw holes?????
