Old 09-01-2009, 02:10 PM   #1
epashhans
epashhans's Avatar
Gas sucking out of my locking gas cap!
So when I got the truck it had an older locking cap so I figured it had a leak or something and got a new cap. Now its still doing it! When I drive down the road its coming of the center of the cap and blowing down the side of my box! Has anyone has this before? Doesn't seem to do it when the tank is lower with fuel...but I want to be able to fill it up. Some kind of suction going on? I currently have an electric fuel pump going to a 454 with an edelbrock/carter on it. Anyone have any ideas? I did order a new gasket for the sending unit because it has a small leak...could that be causing it? Thats the next thing I am going to try!
'67 C-10 Shorty - 454, 5spd, and speed holes!
epashhans is offline   Reply With Quote
Old 09-01-2009, 02:17 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Gas sucking out of my locking gas cap!
Sounds like you need a vented cap.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-01-2009, 02:57 PM   #3
epashhans
epashhans's Avatar
Wouldn't it just come out the vented cap as well?
Old 09-01-2009, 03:30 PM   #4
vectorit
What?
vectorit's Avatar
Check the vent tube on the tank, since they tend to get pinched off sometimes against the body.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 09-01-2009, 04:15 PM   #5
epashhans
epashhans's Avatar
Thanks, I will look there too.
Old 09-01-2009, 05:39 PM   #6
westbrookw
LET'S GO...MOUNTAINEERS
westbrookw's Avatar
I had something similar with a mechanical pump. It was sending fuel back in the return. I had to replace the mechanical bc it ruptured inside. Maybe the pressure is too high on the mechanical. Not sure.
72 SWB/Step
westbrookw is offline   Reply With Quote
Old 09-01-2009, 03:59 PM   #7
Ace in the hole
vented caps do it too, it happened on my 70 all the time with a new vented locking cap.
67-70 do not have a vented tank so you are kind of stuck with a vented cap and I don't think you can get away from some sort of spillage when the tank is full.
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 09-01-2009, 04:09 PM   #8
Sinister
Between Trucks...
Sinister's Avatar
Could it be the locking cap? I run a regular vented cap and can fill the gas tank pretty full with no spillage.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
