Member #1049
1972 Rochester 2bbl Carb
factory for a 1972 with a 2BBl.. looks fairly clean. has fast idle solenoid still attached.. No idea on working condition, pulled it off of a dead engine. will probably at least need a new gasket kit.. $40.00 shipped
Truck Junkie
![]() Join Date: Aug 2008
Re: 1972 Rochester 2bbl Carb
are either of the carbs in your post 2Gs
Member #1049
they are both 2GV's...
There are three basic 2 Jets. the differences are the 2G's use a remote manual choke.. the 2GV's used a thermostatic choke and the 2GC's used an integral automatic choke.. |
Active Member
![]() Join Date: Dec 2003
I'm interested will you take $35.00 shipped.
Truck Junkie
I would need three, with at least 1 that has a thermostatic or automatic choke.
Member #1049
72swbcamo Yes, I would take $35.00 shipped
lo72 sorry, I only have the two.. both have the thermostatic chokes. Sounds like your putting together a tri-power set up? |
Truck Junkie
yeah that is my plan. i have 2 of the carbs but the fuel inlet is on the front not the side...
Active Member
Livrat: Do you have the choke assembly from the manifold? If yes how much and how do you want for it. How do you want to get paid, is a money order OK?
Member #1049
Sorry I do not have the thermostatic coil assembly for the manifold... A money order is fine for the carb... PM Sent
