Old 09-02-2009, 12:37 AM   #1
hgs_notes
GEARHEAD
hgs_notes's Avatar
hard top mounting question
All the blazers/jimmys I've had so far came with single wall tops. So I'm familiar with how they are bolted in. But the yellow tub I bought for my 2wd came without a top, and the bed rails just have holes, no threaded plates. Is this how the double wall tops were set up normally? If I want to use a single wall top, do I just need to use nuts and washers then to bolt it down?
hgs_notes is offline   Reply With Quote
Old 09-02-2009, 02:04 AM   #2
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Re: hard top mounting question
Right, double wall tops bolt up from the bottom, there's a strip inside the top with captive nuts for the bolts to thread into. If using a double wall top, I'd run a tap through the holes to clean them out real well prior to. Can't remember if they are 3/8 or 5/16 though. Someone else on the board will know for sure tho.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 09-02-2009, 01:45 PM   #3
tdkosta
tdkosta's Avatar
Anyone recall the size of the bolts?
tdkosta is offline   Reply With Quote
Old 09-02-2009, 09:16 AM   #4
hgs_notes
GEARHEAD
hgs_notes's Avatar
Thanks for the info. So it looks like I can use either top easily enough.
Old 09-02-2009, 11:05 AM   #5
litebulblsc
litebulblsc's Avatar
I believe the single and dual wall tops bolt holes are in different locations, so you would have to drill new holes for the single wall top
litebulblsc is offline   Reply With Quote
Old 09-02-2009, 03:32 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
They do bolt on on different locations on the bed rails.. I use carb studs to bolt on my double wall top...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 09-02-2009, 07:30 PM   #7
Otsa580
I Love Rusty Chevys
Otsa580's Avatar
I saved this off a previous thread:
5/16 coarse thread I believe 18 thread. You can drill and tap to 3/8 if you need to.
1969 K5 Blazer
1997 1500 Silverado Ext Cab Z71
2010 1500 Silverado Ext Cab Z71
Otsa580 is offline   Reply With Quote
