Old 09-02-2009, 08:35 AM   #1
nu2-72
help identify column
I am wanting to rebuild this column if it is a correct truck tilt. If it is a van of some other then I won't waste my time. How do you correctly identify a column? Total length, wiring, lower length? Thanks for any help.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 09-02-2009, 08:59 AM   #2
msgross
msgross's Avatar
Re: help identify column
The length will tell you, shorter is a truck..
I don't know the correct length though, sorry.
according to the tilt/turn levers it's period correct though.
I'm rebuilding a van tilt, only issue is that I have to shorten the middle shaft in the engine compartment.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 09-02-2009, 10:02 AM   #3
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Looks like truck tilt to me.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 09-02-2009, 04:56 PM   #4
nu2-72
So the first thing I am hearing is that size matters. Sorry.
Kevsclassics, what tipped you off?
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 09-02-2009, 05:27 PM   #5
john
member #16
john's Avatar
A pic of the whole column will help. It looks like the rubber seal on the column is the truck type,also the wire connector. Wheres the N/S switch?
john is offline   Reply With Quote
Old 09-02-2009, 05:39 PM   #6
leddzepp
Moderator
leddzepp's Avatar
x 2
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-02-2009, 07:32 PM   #7
KevsClassics
TILT COLUMN GURU
The 2nd pic is dark but I see where the intermediate shaft connects to the end of column is correct of a truck, plus the dash seal is for a truck. take a better pic of lower end of column so we can see location of nuetral safety switch and I can tell for sure.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
RIP EL JAY
Old 09-02-2009, 06:47 PM   #8
sweet70beast
sweet70beast's Avatar
Need a better pic of the bottom of the column where the lower shaft bolts to it. The length of that will help determine which it is. Van is longer, truck and motorhome is shorter but the N/S on the motorhome is in the vans position.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
