09-02-2009, 04:30 PM | #1 |
Media Blasting Equipment: Suggestions Please!
i recently got a quote on how much it would cost to have some small parts media blasted at a shop, so i went hunting around thinking i may be able to do it myself. i found this blaster from harbor freight, so i'm curious as to what you guys think, or if you have any other suggestions. thanks
http://www.harborfreight.com/cpi/cta...emnumber=30979 i mean it's only 30 bucks plus the media, so i was thinking it was worth a shot...
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
09-02-2009, 05:42 PM | #2 |
a fool with no money
Re: Media Blasting Equipment: Suggestions Please!
I bought that... bought more hose at Lowes and put a piece of alum. tubing on the end and just jammed it in a sugar sand sack (also at lowes)... I got tired of filling that tote pack... worked good
Basicly stock 83 SWB with a few Bolt-ons before, during and still during http://photobucket.com/albums/y251/moostifer/truck/ http://photobucket.com/albums/y251/moostifer/motor/ Last edited by Moostifer; 09-02-2009 at 05:43 PM. Reason: added sugar |
09-02-2009, 06:19 PM | #3 |
Wear a good respirator (not a little paper filter mask) or you can cause sever lung damage!
My Truck's not leaking its marking its territory! |
09-02-2009, 06:35 PM | #4 |
i dont see why that would'nt work for small parts. but a warning... sandblasting gets crazy. it cleans things up so well that you will want to sandblast everything.
if you get into bigger stuff you will need a big compressor.
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
09-02-2009, 07:33 PM | #5 |
haha i can imagine, i've seen how well the parts you blasted and painted turned out. that's sorta where i got my inspiration
09-02-2009, 07:42 PM | #6 |
glad i could inspire!
09-02-2009, 08:47 PM | #7 |
There ius a company that I buy my media and misc. parts from called Tip. I'm sure they have a web site you could check out. They have everything you could need to blast small and large parts.
2010 Tahoe 1984 C10 2005 Harley FLH 1941 Willys Pickup (will never get it done) not for sale |
09-02-2009, 09:39 PM | #8 |
I wouldn't use it to do body parts though.
See if there is a soda blaster in your area. Some even have them setup in vans and they will come to your house. Plus baking soda cleans up easyier then sand or other abrasive media.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
09-03-2009, 12:16 AM | #9 |
Why don't you get a small blast cabinet?
Adam M STX Designs Motorcycles | Choppers | Hotrods |
09-03-2009, 02:33 AM | #10 |
thought about it, but this blaster would give me the option of doing slightly larger parts too, but i don't plan on using it on body panels.
09-03-2009, 07:32 AM | #11 |
I have a blasting cabinet from Harbor Freight that does a really good job. And if I have something to big to put in it, I just take the sprayer doo hickey out and put some sand in a bucket and use it outside. That way I have the ability to do either. And, it does take a big compressor
09-03-2009, 11:13 AM | #12 | |
09-03-2009, 11:40 AM | #13 |
i have a blast cabinet that i wish i had never bought. its hard to see the parts in there and the plexi glass gets real pitted makes it worse.
i used a small cambell-hausfeld 6cfm@90psi and about burnt it up. i bought a mac tools 2 stage 80 gallon that is unstopable 18cfm@100psi. just remember bigger is better w/ compressors. it was a big investment for me and i researched for months before i bought mine. i love mine and i know i'll never run out of air! running a sandblast gun out of a 5 gallon bucket taxed the heck out of it nonstop for hours on end and it would just catch up and shut off within minutes while never having to stop blasting.
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list Last edited by menace121978; 09-03-2009 at 11:42 AM. |
09-03-2009, 01:10 PM | #14 |
Yeah, my compressor is a 60 gallon, 6.5 hp & 17.25 cfm @ 90 psi and I have had it since '96 without issue. I had a small Craftsman compressor before it, and it wouldn't even keep up with a die grinder for very long.
As far as the cabinet, I did add a light inside mine (LED light w/ a sealed plexi cover) so I can see and the plexi seems to be holding up really well. I have had it for about 10 years and have only replaced the gloves once. |
