Old 09-03-2009, 12:30 PM   #1
BIGBLU 72
BIGBLU 72's Avatar
What clutches do you run?
the clutch in my truck is starting to go. i have no clue what kind of clutch is in it now. my Jimmy is a granny gear four speed and four wheel drive np205 transfer case and powered by a 400 hp-ish (give or take 25 hp) 400 small block. so my question is what clutch would be best for my truck......its a daily driver and not a crawler, mud buggy but does do some occasional light four wheeling.
68 C10 LWB 2/4 drop 406/th400/3.73posi
04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD
BIGBLU 72 is offline   Reply With Quote
Old 09-03-2009, 02:33 PM   #2
Burt4x4
Burt4x4's Avatar
Re: What clutches do you run?
Luk-Pro Gold is what I have.
Works Great
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 09-04-2009, 08:47 AM   #3
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
I run a McCleod Street Twin but mines a high HP street truck. Id recomend a Spec or Zoom for what you want.
Sorry... Im lusting after your Nova.
Tom Vogel is offline   Reply With Quote
Old 10-11-2009, 01:25 PM   #4
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Works Great
Do you have a part number on the Luk-Pro Gold clutch kit. I looked at one available for a 72 Blazer. The spec said the clutch disk was 11 7/8" in diameter. I measured the current disc and its 11". 11 7/8" takes the disc edge right near the mounting bolts on the flywheel. Did you have to purchase a bigger flywheel or is it different kit than the 11 7/8" . Here is the specs/PN.
Chevrolet Blazer(Full Size), C10-30, K10-30, R10-35, V10-30, Silverado, Tahoe Pro Gold Series - Luk
Part No.: 04-902
Application: PRO GOLD SERIES
Engine: 8 Cylinder
Disc Size
Outer Dia: 11 7/8
Spline: 1 1/8
Teeth: 10
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 10-12-2009, 10:04 AM   #5
Burt4x4
Burt4x4's Avatar
When I put it in I also bought a new Hayes 30lb. flywheel and had the whole assy balanced. I would assume you would atleast need to turn your current flywheel. Any good machine shop should beable to tell you if it will work with a 12"(rounding up) clutch assy.
Sorry no part numbers availabe to share but I think the one you listed is the one I used..
Old 10-12-2009, 05:13 PM   #6
D.PASSMORE
One of the First
D.PASSMORE's Avatar
I asked the machine shop before they turned the fly wheel and they said it wouldn't work. Looks like I will use a center force with a 11" disk. Thanks
Old 10-15-2009, 04:41 PM   #7
D.PASSMORE
One of the First
D.PASSMORE's Avatar
I went ahead and purchased a 11" HAYS, It came with everything and was priced right. Hope it holds up...
