2 tons of fun
Hey guys,
What are the two screws on the front of an edelbrock 1406 carb? Fuel/air mixture? Which one does what? Thanks ------------------ 67 Chevy,Short/Fleet,350,Saginaw 4-Speed,Lowered 4x2,small window,P/S,Edelbrock Intake/Carb,HEI,Gear Drive,Crane Cams 274h Three Rivers, Ca Pic at: <A HREF="http://community.webshots.com/album/29068416etoBoEninp " TARGET=_blank>http://community.webshots.com/album/29068416etoBoEninp </A>
67 Chevy,Short/Fleet,350,Saginaw 4-Speed,Lowered 4x2,small window,P/S,Edelbrock Intake/Carb,HEI,Gear Drive,Crane Cam 274H Three Rivers, Ca Pics at: http://www.cardomain.com/id/lumpy454 |
there both air/fual mix screws. Edel puts on 2 of them just to screw with you.
------------------ 71 basic C-10 350. The only option is the rust.No nothing on it, but thats all about to change. <A HREF="http://www.geocities.com/stevemau/slam33page.html?1004806705410 " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A>
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
high and low speed inrichment screws...screw them out to richin and in to lean...starting at one..either one..i start on the right..screw out until u reach highest rpm..then turn in a 1/4 turn..then repeat with the other screw....or just go to www.edelbrock.com itys a great site, and they'll wlk u through the tunning proceedure
------------------ 67 lwb fleetside...first hotrod in 25 years...283..186 bowl ported heads..270h comp cam 600 1405...stealth intake..HEI..th350 with 2500 rpm stall..4:10 POSI god I love to go fast
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
2 tons of fun
Thanks for the replies. Hey BigJim I went to edelbrock.com but couldn't find anything about these adjusting screws. Thanks
they are both idle mixture screws
if i remember right you turn one clockwise until it idles rough. then turn it counter clockwise, the idle will keep increasing. when it plains off stop and do the same thing to the second screw. then repeat this process after your done turn both screws in equal amounts until the idle drops about 50 rpm. then your set hope thats what you wanted to hear
70 3/4 ton 4x4 FOR SALE Greene, IA |
ps dont forget to drop it off that 50 rpm or you will end up with a slight hesitation
2 tons of fun
Thanks guys.
hey...if u go to the web site...go to auto's...then to carb...then to square bore carb...then click on high lightes owners manual...then scroll down to tunning...lol,,i know its harder than actually tunning the carb...but its worth it
www.edelbrock.com
2 tons of fun
Got it. Thanks BigJim
