Big Block Identification Help
My block casting is 3969854 GM 8 ( is it a 2 or 4 bolt ? for future build up possibility)
My front passenger stamp in front is T I 1 I 8 TBH Manifold Casting is 3955287 66 2 It has no air pump It has a California Q - Jet ? 7040509 QS ( what is QS for ) Mortec states it is a 69 396 2 or 4 bolt Why would it not be a 402? Is it correct for the model / year ? ![]() |
Member #1049
Re: Big Block Identification Help
Mortec also shows the casting number as:
3969854= 402 70-72... 2 or 4 bolt. The front pad stamp further identifies it as: TBH = 1970 Truck 402 310HP L-47 10, 20, 30 Intake comes back as: 3955287 454 / 390 70-71 Vette, LS-5 Cast Iron, Oval Port, Lo-Rise, Q-jet carb 3955287 402 / 350 70-71 Nova, Chevelle, Camaro Cast Iron, Oval Port, Lo-Rise, Q-jet carb 3955287 402 / 300 70-71 Nova, Chevelle, Camaro Cast Iron, Oval Port, Lo-Rise, Q-jet carb 3955287 402 / 330 70-71 Nova, Chevelle, Camaro Cast Iron, Oval Port, Lo-Rise, Q-jet carb 3955287 454 / 365 70-71 Vette, LS-5 Cast Iron, Oval Port, Lo-Rise, Q-jet carb Not able to help you on the "QS" on your Quadrajet.. |
