Old 01-13-2003, 08:10 PM   #1
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Question headliner glue????
I am about ready to glue the headliner back in my truck, and was wondering what all you guys use before I get unsatified looks. I really want the headliner to stick to the ceiling for a long time. I was going to use 3M spray adhesive? but didn't know what you guys used. Thanks Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 01-13-2003, 08:18 PM   #2
Bob Chayer
Construction adhesive worked well on my Sub. Something 2000 was the name and it was in a regular caulking tube. Got it at ACE for a few bucks. Still holding well in the cold after a couple of years. Good luck!
Bob Chayer
71 3/4 ton 4X4 Suburban
Bob Chayer is offline   Reply With Quote
Old 01-14-2003, 12:21 AM   #3
71blksuper4x4
SWB 4x4 Collector
Thumbs up
ttt
TREVOR
Old 01-14-2003, 12:42 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
What ever you do...don't do it like the dope smokin old man did it.
Old 01-14-2003, 08:22 AM   #5
JimKshortstep4x4
Talking
I used the 3M spray adhesive, (the strong grade) and held it in place with a "tee" made out of a 2x4 and a piece of plywood. Same idea as what you would use for holding dyrwall to the ceiling. I made the 2x4 just long enough so that it would fit beween the plywood and the floor. I sprayed the roof and the
headliner, let flash, but not too long and then fitted the liner up to the roof. After setting my "tee" in place, I let it dry for a couple of days, just to make sure.
Jim
Old 01-14-2003, 08:40 AM   #6
70c10
67-72 Addict!
70c10's Avatar
The 3M spray adhesive-90 will work but can be messy if you have never used it. I recently started using pure silicone caulk in a gun. It's very neat and will withstand any humidity build up in the cab. Plus if you have to ever remove it, the silicone peels off cleanly without damaging your paint unlike glue. Like JimKshortstep4x4 said - you will need to wedge to hold it up while it cures. Good luck!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-14-2003, 08:53 AM   #7
JimKshortstep4x4
Talking
Silicone? That is interesting.
My concern would be the effect that silicone has if you ever need to paint your truck. Working in a plant that had (4) paint lines
just bringing silicone into the plant would cause panic on the lines. We do not use any kind of silicone in the plant. Not sure if this is common practice for paint lines in other areas but in our area it is and we have lots of paint lines in Western michigan.
Just an observation.
Jim
Old 01-14-2003, 10:16 AM   #8
70c10
67-72 Addict!
70c10's Avatar
Jim,
Silicone shouldn't have any effect on the paint. It peels off easily and would be less harsh than spray glue when it comes time to remove and repaint your truck.
Jim
Old 01-15-2003, 12:18 AM   #9
Longhorn Man
Besides, who cares what the paint looks like on top of the head liner?
