Old 09-10-2009, 10:37 PM   #1
renegade6
Door Hinge replacement 99 Silverado
Anyone have good instructions or tips on replacing door hinges on a 99 Silverado? It looks like someone did a poor job of replacing the pins and as a result, the entire hinges are going to need to be changed.
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 09-11-2009, 12:31 PM   #2
Re: Door Hinge replacement 99 Silverado
I was under the impression they are not really replacable, at least to us normally folks. They are welded in place to the door.
Old 09-11-2009, 02:42 PM   #3
bwood
bwood's Avatar
These guys were advertising on another forums, looks cool.
http://www.totalauto.com/presentation/index.html
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 09-11-2009, 05:57 PM   #4
mbgmike
We sell all the same products from Total Auto.
We have installed many of their hinge replacement kits. It helps to have a door lift though or at least a makeshift if a DIY
mbgmike is offline   Reply With Quote
Old 09-11-2009, 06:03 PM   #5
mbgmike
Impossible to reweld them back on. GM can't even do it. You have to bolt them back on. Send me email and I can send you the factory repair sheets
Old 09-11-2009, 08:22 PM   #6
renegade6
Thumbs up Re: Door Hinge replacement 99 Silverado
PM sent. Thanks
Brandon
Old 09-11-2009, 09:15 PM   #7
mbgmike
Originally Posted by renegade6 View Post
PM sent. Thanks
It should be there Bud.
If you need the service kit we can send you one but any GM dealer should have it
Old 09-11-2009, 09:21 PM   #8
mbgmike
Just for info GM charges like $900 to do this We do it for quite a bit less
Old 08-30-2016, 05:15 PM   #9
dixiegirl1629
Can you send an email to me? My brother needs to replace his hinges on his silverado. My email is dixiegirl1629@aol.com. Thanks.
dixiegirl1629 is offline   Reply With Quote
Old 01-11-2017, 12:44 AM   #10
rudyyloverboiii
I too need help with these hinges. 2000 Silverado. Has lamb o doors n I wanna go back to stock. Help would b appreciated. Pm me
rudyyloverboiii is offline   Reply With Quote
Old 09-11-2009, 05:58 PM   #11
mbgmike
I can send you the Factory replacement instructions from Gm if you want. Give me you email and I can send the file. Easier than you may think
Old 09-18-2009, 10:07 PM   #12
bighaas79
have you tried drilling out the holes and use an oversized bushing?
bighaas79 is offline   Reply With Quote
Old 09-19-2009, 12:44 PM   #13
mbgmike
Thats more work than the factory fix plus i doubt if that would withstand the time. The Factory fix is the way to go on this. Its really pretty simple. you drill out the holes. fish a knurled bolt up though the access hole in pillar. pull it through the oversize hole and bolt your hinge on. If their was an easier way we would do it.
Old 09-20-2009, 09:42 PM   #14
renegade6
Well, finished the top hinge. Not hard to install at all but, getting the old ones off is a PITA.
Brandon
Old 09-21-2009, 06:49 AM   #15
mbgmike
yeah. One of GM's better ideas. The a pillar actually flexes when you open the door if you watch. We have had to fix many of these good money maker for gm dealers
Old 09-27-2009, 07:01 PM   #16
renegade6
It's finally complete. I have to do a little adjustment (2X4 to the door) but, it is a lot better than it was. If anyone is trying this, I would strongly recommend an air chisel.
Thanks to everyone for the help.
Brandon
