Retired Air Force Veteran
![]() Join Date: Aug 2007
Using a Camaro Tach in our Gauge Clusters
Back some time ago (07/2007) Board Member "Gringoloco" did a write up on installing and using a Camaro Tach in our Gauge Cluster (see his build link below). My question is, has any other board member done this (pics please) and were any of the other gauges from the Camaro Cluster used. Looks like the Camaro Tach was from a 70-81.
Thanks http://67-72chevytrucks.com/vboard/s...d.php?t=251017
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
Re: Using a Camaro Tach in our Gauge Clusters
Any Suggestions?
how well has it held up, would you have done anything different now?
Have not done anything yet, I'm gonna look into it more. When I get the Cluster finished, I'll post pics.
SWB 4x4 Collector
![]() Join Date: Jun 2001
I am working on one right now. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
sweet, is it in deed the 70-81 instrument cluster from the camaro. are you using the other gauges? would like to see pics when ur done
I remember the write up, had me wanting to do mine, But sorry never got around to it. So here is a bump maybe we can catch somebody that did do it.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
Location: Sunny, Florida, some might call it South Alabama
I had never seen that before, but i looks very good. I will have to make sure to save that link.
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
SWB 4x4 Collector
I will post pics soon, putting some finishing touches on it, I don't know if I should put a quartz clock in it or not. I am trying to make it look more original than any other one I have ever seen. I plan on selling it on the board here in the next week or so. Trevor
SWB 4x4 Collector
yes, I used a cluster out of a 70-81 camaro. The tachs are different through the years, some are better choices than others, but I can't tell you what years are better than others. You can use the clocks out of them as well, but I hear that the quartz clocks out of 81-87 pickups is better to use. Trevor
Trevor,
Thanks for the info. I'll be getting my Camaro Instumment Cluster here in a few weeks when I go to Jersey. This one Red Lines at 4500 and goes to 7000 RPM. It should look real cool in there. I would like to use most or all of the gauges. Looking forward to seeing pics of your gauges. Thanks Again
Adam B
I did this a couple months ago and it was fairly easy to do. It did take some fine tuning of the back metal part of the dash to clean everything up. It looks great now and very factory.
I did mine on a '68 Chevy truck, where you have the turn signal arrows. I used plastic cleaner, 2000 grit sandpaper and small bit of water to remove the turn signal arrows. I don't have the turn signal arrows, but I just try to remember if I turned the turnsignal on/off. I would highly recommend this. They sell the tachs on e-bay for $10-$40. Adam --if i remember, i will take some pictures to post. |
Great Job¡¡¡ GRINGOLOCO found this post and you give me ideas because I already bougth an used gauge cluster and I was thinking to do what you did, so now I need to buy the tach., basically you did the job for many of Us.
Thank you |
"Trucks with Class"
You can use the 130mph speedo or 150mph Z28.
Z28 also had a 8K tach! Notice if you take off the stock gas gauge markings you can redo them inside the gauge and they match the size of the speedo. See pics. |
#15 |
frank, what year z28?
#16 |
From what I have seen on ebay the Z28 tach and speedo fetch a pretty penny.
#17 |
I have the 70-81 Camaro Instrument Panel (I'll actually be picking it up next week) and want to use all of the gauges from it for my C-10 Bezel. According to PICKMUP the Z-28 Panel my fit a bit better. Like I said I get it next week and I'll be out of town for a few weeks. As soon as I get it done, I'll post pictures
#18 |
Adam B
Sorry for the delay in posting the picture.
Here is a picture of my gauge cluster. The tach is from camaro, 70-82 I think?? Adam |
#19 |
Wow Adam! That tach looks really good in our gauge bezel. Was there allot of fab work to fit it? If so, please share any info as I am really interested in fitting one for my 69' Stepside. Thanks for the picture.
#20 |
![]() Join Date: Aug 2008
subscribing!
Nick "Everyone has a plan, 'till they get punched in the mouth".........Mike Tyson 1968, GMC, SWB, Project 1972, GMC, LWB, Daily Driver, 383, headers, 2.5"/3" exhaust, 200r4, 3.5/5 ECE components. 1972, C/10, LWB, 350 vortec, th350 |
#21 |
subscribed.
I wonder what the black tach would look like with all the rest of my gauges being white............ |
#22 |
Redefining LowBudget
I'm in??? now what did I do with that spare truck dash?? I need a fuel guage needle??
one questoin when you swapped needles how did you get it where it belongs in relation to the one you took off??
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#23 |
SWB 4x4 Collector
Here's one I have been working on:
#24 |
Now what is that tach out of ?
#25 |
SWB 4x4 Collector
It's out of the same years of camaros.
